slip joint on the drive shaft??? axel wrap??
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04prerunner, Feb 11, 2010.
  1. May 3, 2010 at 11:25 AM
    scocar
    scocar Patron of the Farts
    Cool. Yeah, the lube won't eliminate axle wrap, but helps a bit with the clunking/jerking caused by axle wrap and is a necessary service item every 15k miles.
  2. Jul 7, 2010 at 5:34 AM
    Dwagner1006
    Dwagner1006 Member
    This sounds like the exact problem I am having.
    Is this a known issues on the Gen2 taco's as well?
    I have a 06 ext cap trd sport
    Thanks guys!
  3. Jul 7, 2010 at 5:44 AM
    ywen
    ywen Well-Known Member
    This is an issue with all leaf spring setup, when the springs are weak.
  4. Jul 7, 2010 at 5:50 AM
    Dwagner1006
    Dwagner1006 Member
    Ok. i will see what I can do about getting some new springs then.
    Thanks!
  5. Jul 7, 2010 at 8:24 AM
    scocar
    For the 2nd gens, yo umight want to look into the leaf spring TSB (I think that is what it is called, but I don't have a 2nd gen). It is all over this site. Try starting with a search under the suspension topics. Hmm, maybe it was AAL (add a leaf) TSB. Basically, Toyota adds an extra leaf to the stock leaf pack for you to correct the payload capacity, which is related. IIRC.
