Slip yolk eliminator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoNewbiee, Aug 3, 2016.
  1. Aug 3, 2016 at 4:55 AM
    TacoNewbiee
    TacoNewbiee [OP] Member
    2014 Tacoma 4x4, Regular cab
    Hey guys, does anyone know of or where I can get a slip yolk eliminator? I have a 14 taco regular cab and can't seem to find one. Thanks!
  2. Aug 3, 2016 at 8:04 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    why ? the slip is already in the driveshaft and not on the tranny output
  3. Aug 3, 2016 at 8:28 AM
    TacoNewbiee
    Long story short, I self installed a 3in rc lift kit and now I'm getting some drive line vibration. I thought maybe the lift raised the drive shaft angle up to a point where it's putting some strain on the drive line. I figured maybe the slip yolk would fix the problem.
  4. Aug 3, 2016 at 8:53 AM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    you need a slip yoke on the driveshaft, there is no reason to eliminate it.
  5. Aug 3, 2016 at 10:05 AM
    TacoNewbiee
    Is there anyway then to lower the drive shaft a bit to deal with the vibration?
  6. Aug 3, 2016 at 10:13 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Carrier bearing drop maybe? :notsure:
  7. Aug 3, 2016 at 11:12 AM
    Pigpen
    Dan
    Northwest Montana
    CB drop. Read and understand the thread on drive shaft angles before you just start throwing in spacers and getting frustrated.
    DaveInDenver likes this.
  8. Aug 3, 2016 at 5:49 PM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    There is no carrier bearing on regular cab trucks (one piece driveshaft). The only way you can change the angle of the driveline is by installing shims under the leaf pack.
    jagergirll and TacoMitch93 like this.
  9. Aug 3, 2016 at 8:11 PM
    Pigpen
    Dan
    Northwest Montana
    Good catch! I didn't even look to see if he was driving a RC.
  10. Aug 3, 2016 at 8:19 PM
    PSU Taco85
    optional
    Regardless. A there is no SYE for our trucks. The slip joint is already in the driveshaft not the tcase. Best way to get rid of vibes is a one piece DC shaft
  11. Aug 3, 2016 at 8:35 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    No, no, no, don't just guess and buy parts. Odds are you will compound the problem and make the problem more difficult to solve. First read this quick link on driveline basics. http://www.4xshaft.com/driveline101.asp. Then read this one that shows how to check your angles. http://www.4xshaft.com/tech_slopesVSangles.asp. Then you can actually begin to correct the problem.
  12. Aug 4, 2016 at 8:03 AM
    TacoNewbiee
    chill out guys I haven't bought anything. I'm just spitballing ideas. I can't do a carrier bearing drop because my drive shaft doesn't resemble the ones featured in many of these threads. It seems to be so short that it's just suspended between the transmission and rear axle because it's so short. So there isn't a carrier bearing to lower.
  13. Aug 4, 2016 at 8:34 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    this is solvable by you doing some work
    1) careful measuring of the existing angles according to
    [numerous web articles on driveshaft alignment and vibration woes]
    2) shimming the leafs to get the correct angle on the pumpkin
