Slipped LCA bent cam tabs, Dealer wants to replace frame $26k
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacoma_ca, Aug 30, 2025.
  1. Aug 31, 2025 at 5:25 AM
    #41
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Ahhhhhh, and now the truth out's itself. Dealer CYA.
  2. Aug 31, 2025 at 8:25 AM
    #42
    tacoma_ca
    tacoma_ca [OP] Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    It was aligned 5k ago by dealer but I haven't been able to look at it yet. Hopefully after getting sone ideas here it will be clearer what happened when I can check it and look for evidence.
  3. Aug 31, 2025 at 8:32 AM
    #43
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    I just did a big suspension refresh on my BMW 135 and I noticed that the cam tabs on the 3400lb car are significantly beefier and better designed than the ones on the front of a Tacoma.
    tacoma_ca[QUOTED][OP] likes this.
  4. Aug 31, 2025 at 8:38 AM
    #44
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Once again, it mildly irks me that people use the words "Toyota" and "dealership" as synonyms. No way the dealer franchise even called Toyota over that one.
    Get the aftermarket tabs. Leave the dealer a terrible review and then move on.
  5. Aug 31, 2025 at 8:43 AM
    #45
    Taco-Grinder
    Dan
    Fond du Lac, WI
    If your tab is not broken off, bend it back. Then put weld bead to hold it in place. Then put a weld bead on all your other tabs. I had the same thing happen to me. That was about 5 years ago. No problems since.
  6. Aug 31, 2025 at 8:53 AM
    #46
    tacoma_ca
    Thanks I changed the title from Toyota to dealer.
    Rock Lobster[QUOTED] likes this.
  7. Aug 31, 2025 at 9:24 AM
    #47
    fxntime
    Small block of steel 1/2'' x 1/2'' by length of tab. Bent tab back carefully. place water soaked rag over rubber, weld block behind tab taking time to keep the rubber from getting too hot. It should never fail again. Just welding the tab itself isn't enough, it needs to be braced higher so there is support behind the cam area.
    Even a 120v buzzbox should have zero issues with this.
    usmc2msu and tacoma_ca[OP] like this.
  8. Aug 31, 2025 at 10:45 AM
    #48
    OvrlndBigAl
    OvrlndBigAl Well-Known Member
    Alex
    Some where in Idaho!
    Cement 2019 TRD OR DCSB
    Just a Snug Top with Sportsman’s package 1 inch lift and 265/75-16 Duratracs.
    This is the solution, simple and effective. I’ve worked with some great techs over the years but the overall state of the automotive industry is pretty sad.
  9. Aug 31, 2025 at 11:54 AM
    #49
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Multiple people do it often. And it's a very mild pet peeve. I'm not exactly going to draw lines in sand or burn friendships over it.
    :cookiemonster:
  10. Aug 31, 2025 at 3:01 PM
    #50
    Clearwater Bill
    Billy
    Largo Florida
    I would also remove auto brake from the title
    That was not the root cause, even if they failed under that event. They would have eventually failed during some other event anyway.
  11. Aug 31, 2025 at 3:12 PM
    #51
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    tacoma_ca[OP] likes this.
  12. Aug 31, 2025 at 3:38 PM
    #52
    lbhsbz
    lbhsbz Well-Known Member
    You've gotta be kidding me with this. Get a cold chisel under that tab, bend it back straight and run a bead of weld between it and the frame to support it, realign the truck. $26K estimate at the dealer? You don't even need that tab, it just makes it a bit easier.....use a prybar instead, leave the tab alone, tighten the bolts properly and it won't happen again.
  13. Aug 31, 2025 at 3:39 PM
    #53
    tacoma_ca
    Agreed, this what I am realizing as the root cause has become more apparent. Good to know most 3gens can typically handle a sudden stop. Is it fairly certain the root cause is under-torqued LCA bolts after a dealer alignment? I'll get a chance to look at it soon too so will grab some pics.
    I agree the bent tabs are not designed to support any load under power so the LCA bolts seemingly slipped as a separate issue. Thanks for the groupthink on this as the truck is stock and I have never dug into the front end before.
    Toy_Runner likes this.
  14. Aug 31, 2025 at 4:31 PM
    #54
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Now that you and I/us know more about the actual problem, I'd like to offer some reasonable "to me" advice. Talk to the dealer who did the alignment pointing out that a loose bolt is the most likely cause of this problem - an emergency STOP should never have been blamed. If he comes around to seeing it this way and wants to or is willing to make amends have the work done at a GOOD 4x4 shop. The dealer will most likely not be equipped or willing to do a job that is not a Toyota approved repair, hence the frame replacement. If the Service Manager refuses, take the issue to the Manager and then the Owner. You could also take it to Toyota Corporate, if all else fails.
    If you are dealing with any type of an honorable dealership, I bet someone there is already thinking they made a mistake in their communications with you.
    OR just have the work done at your own expense. I do not agree with the other posters who say this work will increase the value of your vehicle, nor do I agree with any decrease in the value - it is a wash and not noticeable to almost anybody. The only value would be seen by a true 4-wheeler, but then one of those people, I am one of those people, would be willing to do it themselves to get it done correctly.
    Good luck with this issue next week.
  15. Aug 31, 2025 at 4:51 PM
    #55
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    This. You can add a bit more beef behind it by welding a piece of keystock (https://www.amazon.com/Steelworks-C...id=1756684083&sprefix=keystock,aps,175&sr=8-8) behind the tab. Then, give it a slap and say: That shit ain't goin' nowhere!
  16. Aug 31, 2025 at 4:52 PM
    #56
    Bishop84
    Bishop84 Well-Known Member
    We set the alignment and bend the tabs back in. But the offroad gussets are all you can do for a 100% fix.
  17. Aug 31, 2025 at 4:55 PM
    #57
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Tons of people wheel their trucks and never had tab flattened. Your case has nothing to do with the design.
  18. Aug 31, 2025 at 4:59 PM
    #58
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I still want to see what is logged in the service history.
    Go to toyotaowners.com, make an account and enter your VIN. You can now see all the service the dealer has ever done.
    I use the site every time I research a used Toyota. You don't even have to own the vehicle to do the check, you just need the VIN.
    RustyGreen likes this.
  19. Aug 31, 2025 at 5:02 PM
    #59
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I just wonder if OP’s Truck is the one in his Avatar….
    tacoma_ca[OP] and TACOTU3 like this.
  20. Aug 31, 2025 at 5:34 PM
    #60
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    only way those tabs would of bent so easily is of the cam bolts were loose. im on page one commenting this so idk if its already been said but you could just bend the cam tab back. realign truck and itl be fine. average drive isnt gona hit something hard enough to move the cams when properly torqued
