Slippery high speed driving and 4wd?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dan1, Nov 3, 2022.
  1. Nov 3, 2022 at 4:49 AM
    Dan1
    Dan1 [OP] Member
    Dan
    2022 Tacoma Manual OffRoad
    This time of year around me the fast mountain roads get slippery with rain, leaves, light snow etc... Then there are stretches where the pavement is fine, around a corner and slippery and wet. Also, highway driving in high rain situations, I would normally go from 2wd to AWD...
    I guess I am accustomed to having the AWD option. With my Tacoma I'm afraid to use 4wd at these higher speeds and risk damaging the diffs and t-case.
    What settings should I use in the Tacoma in these situations?
    BTW its a 2022 Off Road, Manual Trans.
  2. Nov 3, 2022 at 5:03 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Go slower. No joke. No smart ass.
    4 hi is good to like 50 or 55mph i think. But still, go slower.
    50Buck, Goodnasty, Tacospike and 15 others like this.
  3. Nov 3, 2022 at 5:04 AM
    MTB_Tacoma
    MTB_Tacoma Well-Known Member
    2022 Electric Lime Tacoma TRD Pro MT
    On my RAV4, AWD is not an option per say. It will just engage when necessary and it will always disengage over 50 km/h. There’s a button to force 50/50 front/rear, but that’s about it.
    On the Tacoma, it’s not AWD (power where needed), it’s 4WD (power to all the wheels).
    If you’re not flooring it in slippery corners, I guess you don’t need to use 4WD? It’s for traction, not grip.
  4. Nov 3, 2022 at 5:09 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    There’s no harm to the 4wd system based on speed alone but if there’s too much traction and you’re driving around, it can bind up stuff because there’s no center diff to allow for slippage, which is what an AWD has. You can switch between 2hi and 4hi on the fly as needed, which is what I would do. Or just slow down, or get better tires.
  5. Nov 3, 2022 at 5:37 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Just slow down, you'll still get there.
    .劉煒, Chew and Junkhead like this.
  6. Nov 3, 2022 at 5:43 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
    An AWD system and the part time system in the Tacoma are not interchangeable in function. The Tacoma system is intended for low traction situations like snow, dirt, mud -- in other words off road use or heavy snow.
    Lots of folks coming from sedans and SUVs don't understand the design intentions of the part time system. If you feel you need 4wd in the conditions you have described you need to slow down, probably quite a bit, seriously - not trying to be hard on you.
    Slow down and live to drive another day.
    BTW: 3 pedal job :thumbsup::thumbsup:
    50Buck, Chew and zoo truck like this.
  7. Nov 3, 2022 at 9:33 AM
    Dan1
    Dan1 [OP] Member
    Dan
    okay. I am a careful driver. Things just sneak up on you this time of the year in the northeast. I like having more as many square inches of rubber as possible responding to my input as opposed to mass and momentum. Maybe that makes sense. I guess one could argue a car ultimately does respond only to my input. Anyhoo...
    SilverBulletII likes this.
  8. Nov 3, 2022 at 9:38 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I mean the fronts still steer and brake, just as much, without use them as drive wheels.
    Low speed; yea you can use front wheels to pull in to a skid, but I highly doubt at highway speeds you’re not going go be able to racy that fast.
  9. Nov 3, 2022 at 9:42 AM
    JackSparrah
    JackSparrah Well-Known Member
    1999 SR5
    Sand bags in the bed?
  10. Nov 3, 2022 at 10:13 AM
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    Yup. 2016 TRD OR, AT.
    In our winters in Kelowna, the ice and snow seldom leave the city streets. Mountains of course much worse.
    I have about 500 pounds of weight in my truck bed in winter. So 5 of the 50 pound sandbags, and then over 300 pounds from my toolbox and spare. I have tried less and more, but 500 pounds is about right for the horrible ice we can get here.
    We can get up to a few feet of snow in the city in winter, and I am in full time 4WD about 30 days each winter. Other days switching in and out as needed.
    Plus I have quality snow tires. Even then it is difficult to get around here in winter. The Tacoma is just not as capable in snow as a full size pickup.
    That is where I miss my old Ford pickups. My Tacoma does not compare to how sure footed those were in city snow driving. Heavier, plus wider stance. Even then I carried 400 pounds in the back of those as well. Driving with an empty pickup in winter is just plain stupid.
    Exception are areas where it is really cold, say always below -10c. Then it is not so bad as the moisture is sucked out of the snow from low humidity and it is not half as icy as driving in snow in milder temperatures. One winter in Calgary, I drove a 1970 Firebird Formula 400 with no snow tires and no weight in the back, and barely spun a tire. The snow dry and grabby. I love it here when it stays below -10c, it is so much easier to get around. Once it gets to -4c and warmer it is a bitch to get around.
    Last winter I make my sharp turn to head up a steep hill to get home. Just a skating rink sheet of ice up the hill. Behind me is a new Tacoma 4x4 with no snow tires, no weight in the back. He does not even make it 10 feet up the hill. I watch as he spins and spins and up and down, and then backs down and takes a different route. Enough said.
    My wife has a RAV4 AWD. The button you can press to allow 50/50 traction only works below 40kmh, or 25mph. Once you go over that speed it disengages and you are back to AWD kicking in as needed. That button still useful when you are in the bad stuff and goimg below 40kmh
    Her RAV4 with same snow tires, is not as good in the snow as the Tacoma is with the weight in the back. So most bad snow days her vehicle sits and I drive her to work.
    Gear Jamin Jamie and Junkhead like this.
  11. Nov 3, 2022 at 10:16 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I remember every year in Colorado when we would get the first ice and snow, the out of state douchebags in their four-wheel-drive bro trucks and Jeeps would wind up in the ditch because a lift, speed, four-wheel-drive, and mud tires are a recipe for disaster.
    I would get some type of snowflake rated tire if you are slipping around and slow the eff down.
  12. Nov 3, 2022 at 10:19 AM
    Little Lion
    Little Lion Well-Known Member
    2018 Barcelonian Sport MT
    good tires and a high gear, I put in 4x4 on ice and in heavy rain, you’re right it does get slippery! Check your tire pressures and yeah if nothing else - just slow down and enjoy life.
  13. Nov 3, 2022 at 10:24 AM
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    My wife drove through a snowstorm going up the rim here in az in a front wheel drive sedan and drove out better than jeeps and tacos. It’s all about the driver, not the machine
    Phlogiston, ppat4 and zoo truck like this.
  14. Nov 3, 2022 at 10:29 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    But what if I'm just a terrible driver? I still wanna make it!
    ret42, ppat4 and MulletTaco[QUOTED] like this.
  15. Nov 3, 2022 at 10:31 AM
    MulletTaco
    Kevin
    Somewhere in AZ
    Keep the throttle consistent and drive it out. Worst thing you could do is slam the brakes or accelerate too quickly.
  16. Nov 3, 2022 at 10:36 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Get a Subaru or Ridgeline if you drive like that. Otherwise, you got the wrong drivetrain as it is not designed to go from different traction conditions at high speed.
  17. Nov 3, 2022 at 10:38 AM
    zoo truck
    None
    I'm in the northeast to, but kind of confused what you mean by things sneaking up on you. If your not aware what your doing, yeah i can see it.
  18. Nov 3, 2022 at 10:39 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    lol I spent 55 years in the snow mountains and the only thing to sneak up on the road is deer. I knew if the roads were half plowed, salted or buried or dry. I knew when they were all of the above in one mile of pavement. That's when you slow down.
  19. Nov 3, 2022 at 10:42 AM
    19992021Taco
    19992021Taco Well-Known Member
    1999 and 2021 Tacoma
    I've had snow the last 2 days with winding mountain roads. I just try and slow down. If the snow builds up at all I put it in 4wd. Been doing this for years in my 99, everything is good to go.
    I haven't driven the 2021 much in snow but when I do it's the same process.
  20. Nov 3, 2022 at 11:08 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    4wd will get you going faster in slippery conditions. It will not effect braking but it will absolutely make your handling much worse. Turning in 4wd requires wheels to be able to slip or your driveline binds. Do you really want to go faster and reduce your ability to turn in poor conditions? Yikes. This mentality is why 100% of the vehicles overturned in the median in the winter are trucks and suvs
    Gear Jamin Jamie, .劉煒 and ppat4 like this.
