Slipping transmission 2013 tacoma
Discussion in 'Technical Chat' started by CaptK2, Jan 25, 2014.
  1. Jan 25, 2014 at 4:29 PM
    CaptK2
    CaptK2 [OP] Member
    Rhode island
    13 toyota tacoma 4 door 4x4
    Snow plow, cap , KN air filter
    My tacoma has 40k , it's a 2013 , for the past few months I've had a slipping issue at slow speeds , usually within the first hour . Sometimes it does it once , than some times five times in a row . But it does not happen all the time . I've kept a log of time , temp outside , engine temp , weather it's wet or dry out side ... The dealer says they can't get it to happen when they drive it ...does any one have any ideas ?
  2. Jan 25, 2014 at 4:30 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Take it to a trasmission shop for diagnosis?
  3. Jan 25, 2014 at 4:33 PM
    CaptK2
    CaptK2 [OP] Member
    Rhode island
    I'm meeting with the Gm , service manager and the Master Mech. On Monday at toyota . I just wanted some feedback...
  4. Jan 25, 2014 at 4:34 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Have them keep it overnight and they can try it in the morning.
    I've read that some Tacomas have left the factory with as much as 2-3 quarts low on the sealed system. Ask them to check the level of the fluid.
  5. Jan 25, 2014 at 4:34 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Dealer
    again
  6. Jan 25, 2014 at 4:37 PM
    CaptK2
    CaptK2 [OP] Member
    Rhode island
    So let's say the fluid is low , judging by how much junk is loaded on the magnet when they pull the plug , cai I demand new innards ? Under warranty still
  7. Jan 25, 2014 at 4:46 PM
    OZ-T
    Peter North
    British Columbia
    Why don't you take it to the dealer and make them deal with it ?
  8. Jan 25, 2014 at 4:49 PM
    CaptK2
    CaptK2 [OP] Member
    Rhode island
    It goes to the dealer on Monday , I just wanted to see if there were any ideas from the crowd !
  9. Jan 26, 2014 at 7:47 AM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    Ask the dealer to watch when they first check the fluid level, and after they've topped it off. If it was low MAKE them document it in case you have any trouble later. Hope this helps.
  10. Feb 25, 2014 at 8:35 AM
    cdn kayaker
    cdn kayaker Active Member
    Eastern Canada
    SR5 with Tow Pkg
    I have a 2013 V6 DC LB AT
    My driveway is steep but not stupidly steep.
    10, 219km (+/- 6k miles). 1st service completed at 8269km.
    Pulled head long into my driveway an hour ago, put it in park, opened door, took my foot off the brake and then it rolled back about 4 feet.
    I stopped the truck from rolling further by jumping back in and hitting the brake. Checked that it was indeed in park.
    Anyone else experience this? I will call the dealerhship shortly.
