Slipping Transmission?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CJ303, Aug 19, 2023.
  1. Aug 19, 2023 at 3:47 PM
    CJ303
    CJ303 [OP] Member
    2006 Silver Tacoma 4x4 Access Cab
    Issue is I’m driving the engine get up to high RPM 4-6 with little acceleration until I let off and let the RPMs settle. Only happens in 2nd and 3rd gear. Slipping transmission?
  2. Aug 19, 2023 at 6:09 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Are you saying that the RPM shoot up to 4,000-6,000 rpm all of a sudden. And that it still “slips” until you let of the gas pedal?
    CJ303[OP] likes this.
  3. Aug 19, 2023 at 7:50 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Please reword your post, the wording is a bit difficult to make sense of.
    It doesn’t have to be technical speak, just tell us what is going on in your own words.
  4. Aug 19, 2023 at 10:06 PM
    CJ303
    CJ303 [OP] Member
    When I go from a stand still and hit the gas in first gear the RPMs go way up to 4-6 thousand range but the truck will hardly move. then once my truck get going a little (10-20mph) I let off the gas RMPs settle to 1-2 thousand. but in order to go faster and shift the same high rev and little acceleration I was able to limp it home around 30 but it’s definitely lacking any power. I found what seems to be a leak this evening. Not sure what it is though
  5. Aug 19, 2023 at 10:19 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Manual or automatic transmission?
  6. Aug 19, 2023 at 10:23 PM
    CJ303
    CJ303 [OP] Member
    Manual
    Dm93[QUOTED] likes this.
  7. Aug 19, 2023 at 10:31 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Sounds like your clutch is slipping.
    TnShooter likes this.
  8. Aug 20, 2023 at 11:02 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    clutch.
