slipping
Discussion in '1st Gen. Tacomas (1995-2004)' started by Thomas670, Nov 21, 2020.
  1. Nov 21, 2020 at 5:22 PM
    Thomas670
    Thomas670 [OP] Well-Known Member
    2002 Taco Regular 5 speed
    hey guys just a question you guys ever had your manual trans slip after changing the fluid to brand new fluid? i havent changed it yet, just curious
  2. Nov 22, 2020 at 4:46 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Changing fluid should not cause this but weird things can happen.
    Only the clutch can slip but if one had a major bearing failure causing enough movement gears no longer can mesh it could slip .
    At that time it very well might sound like a box of marbles in a dryer .
    No most often a slipping clutch means worn Mechanical parts.
    Failed Hydraulics more of a failure to go into gear.
    GQ7227 likes this.
  3. Nov 22, 2020 at 7:39 AM
    Thomas670
    Oh damn thanks for the info because i think the person i bought it from didnt change the trans for awhile if ever. You think i should change it and see what happens? My trans shifts perfectly
  4. Nov 22, 2020 at 11:10 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    When I get another 4x4 all the gear box fluids get changed and the rest of the fluids
    Anything not looked at real close before the purchase gets inspected
  5. Nov 22, 2020 at 11:55 AM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    There's a service internal. Follow it, or don't.
  6. Nov 22, 2020 at 12:04 PM
    eon_blue
    Azusa, CA
    Manual transmissions aren't like autos where if the fluid hasn't been changed in 150k miles it might damage the transmission to change it.
    With a manual you can change it and not worry about that. In fact it I would highly recommend it even if it feels fine...gear oil breaks down over time/miles and should be changed.
    Wulf likes this.
  7. Nov 22, 2020 at 12:06 PM
    eon_blue
    Azusa, CA
    I've never had a slipping issue after changing the oil, only time I've experienced slip is when the clutch is starting to go bad and after a day of offroading through mud. Clutch slipped for a day or two after that but eventually worked fine again, can only guess that mud got into where it shouldn't be
  8. Nov 22, 2020 at 1:26 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Not sure what you meant but what ever .
    GQ7227 likes this.
  9. Nov 22, 2020 at 1:41 PM
    eon_blue
    Azusa, CA
    He means the factory service interval for the manual transmission oil change, I think it's every 50k? Don't quote me on that. I usually do mine around 30k just because.
    GQ7227 likes this.
  10. Nov 22, 2020 at 1:43 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    There isn't anything in a manual that can slip. It either works or it doesn't. The oil is just there for lube and cooling.
    Wulf, Thomas670[OP] and Hobbs like this.
  11. Nov 22, 2020 at 2:58 PM
    ace_10
    Rural NoVA
    Someone with moderator rights has moved my posts around. I don't know why that was done and that's really not something that should be done.
    I never posted to this thread. Nor is the post that is quoted in my post related to my reply.
    GQ7227 likes this.
  12. Nov 22, 2020 at 3:06 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Ummmm, no?
    Wulf and Black DOG Lila like this.
  13. Nov 22, 2020 at 3:13 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I think that you quoted somewhere, and accidentally posted it into another thread. We've all done it. No one's moving your posts around man. I assure you we're not bored enough for that...
    Moving on! :pccoffee:
    Wulf, T-Rex266, Madjik_Man and 2 others like this.
  14. Nov 22, 2020 at 4:14 PM
    Thomas670
    okay sounds great! i am at 114k miles and i will do the oil changes for the trans and differential this weekend. time to give the baby some TLC
    GQ7227 likes this.
  15. Nov 22, 2020 at 4:16 PM
    Poncate
    Poncate Well-Known Member
    PNW
    04 DCSB 4x4
    Shouldn’t affect it. May be clutch? May be worth bleeding the slave cylinder
  16. Nov 23, 2020 at 1:52 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    In any case my point was When I get another 4x4 Having no record of what if any service was ever done I just change the fluids the important word is I .
    After all the quicky mart service can leave something to be desired and some figure as long as nothing breaks why service anything.
  17. Nov 24, 2020 at 7:30 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    this very thing has happened to i on a few occasions, it got moved/merged to somewhere else that i had no access to
  18. Nov 24, 2020 at 7:32 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    somebody on TW claims to have over 400k and 24 years without ever changing any gear oils and it works just fine to this day
    i think it is 30k or 50k depending on use :notsure:
    used to be $20 or so to change (30yrs ago) now its north of $100 is crazy
  19. Nov 24, 2020 at 3:13 PM
    Thomas670
    forreal, i saw the high end gear oil and its like 20 bucks a pop but damn its for our babies tho lol.
  20. Nov 24, 2020 at 5:50 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Redline MT90 and be done.
    eon_blue likes this.
