Slodgetto's Green Dragon 4x4 Conversion Build
Discussion in '1st Gen. Builds (1995-2004)' started by Slodgetto, Mar 29, 2012.
  1. Apr 29, 2012 at 10:50 PM
    #61
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Nice dude! Props for taking on that job on your own, it's definitely not easy.
  2. Apr 29, 2012 at 11:03 PM
    #62
    Slodgetto
    Slodgetto [OP] Über Posre
    Silas
    Thanks, man!
  3. May 1, 2012 at 7:16 PM
    #63
    Cinco
    Cinco Team no taco
    Jose
    Rio Rancho,NM
    2012 Civic Ex Coupe
    What are you 16?
  4. May 1, 2012 at 7:38 PM
    #64
    Slodgetto
    Silas
  5. May 2, 2012 at 6:43 PM
    #65
    Slodgetto
    Silas
    Just got this beast in the mail! :woot:
  6. May 2, 2012 at 9:16 PM
    #66
    Slodgetto
    Silas
    Just thought I'd document my re-gearing adventure a bit...
    Got the third out after resting the axle on jackstands, removing the tires and brake drums, disconnecting the brake lines, and very carfully removing the axles.
    All sealed up since it'll be sitting outside for a couple days..
    The work area:
    Took some measurements of the original gears:
    Total Preload (Pinion/Carrier) = 18 in/lbs start and 3 in/lbs rolling torque :eek:
    Backlash avg. = .009" (within spec)
    Pattern:
    Disassambled everything and cleaned with brake cleaner.
    Comparison shots of the 4.10 and 5.29 ring and pinons...
    GIANT 5.29 ring gear...
    and TINY 5.29 pinion head! :eek:
    Filed down the back of the ring gear and the mounting face on the carrier. Put the ring gear in the oven at 175 degrees for a good 10 min and basically dropped it right on the carrier (no hammering needed), stuck in two ring gear bolts to align it and let it cool before putting in all 10 bolts with red loctite and torquing to 75 ft/lbs.
    Only destroyed one of the old bearings out of all of them during disassembly. Pressing on all the new stuff was a piece of cake with the HF press and the old races and random sockets.
    Decided I wanted to get the pinion preload set first with the solid collar.
    Measured the old crush sleeve to try and get a starting point for shimming. The old crush sleeve measured out to 1.865" and my solid collar measured at 1.815". I figures that I'd like my pinion preload a lot tighter than what it was so I decided to start with .044" worth of shims.
    Took me 9 tries before finally settling on .035" of shims which gave me a very tight 58 in/lbs starting and 19 in/lbs rolling torque. Would've liked a bit less, but the assortment of shims I had for the solid collar were kinda limited. lol :eek: While my pinion bearings might wear out a hair faster than normal, I expect the gear set to be extremely strong and the pinion to have minimal deflection.
    I set the carrier preload by simply tightening the adjuster wheels as tight as I could with my homeade 18" spanner wrenches. (Liberal amount of anti-sieze on the adjuster wheels threads.) The backlash was also not too hard to zero in. After getting about .007" backlash with a good tight carrier preload, I hit the pillars with my brass hamer several times while rotating the pinion in order to sort of shock the bearings and races into equal tension. This was done to get an accurate contact pattern.
    Then it was time to get the contact pattern by rotating the pinion and keeping steady pressure on the ring gear to simulate a load.
    First pattern with .069" of shims... Pinion looked waaaayyy to shallow to me.
    Drive:
    Coast:
    Pinion. Deep on pinion = shallow on ring gear
    Added .010" of shims behind the pinion head and ended up dropping the third trying to tighten down the adjuster wheels!!!! :anonymous: Bent the flange and smashed my e-locker sensor plug! :mad:
    Anyway.... After some :annoyed: and :frusty: I got this pattern with the extra .010" behind the pinion head:
    Perfect! :) Slightly deep and slightly favoring the toe on the drive, which is desireable for a strong gear set. :cool:
    Put everything back together with loctite and correct torque specs. Also added the oil splash washer and seal on the pinon with some RTV. Easy to install using one of the old races and careful use of the hammer.
    Red loctite on the flange nut, and dinged the end! Ready to put back in the truck! :woot:
  7. May 2, 2012 at 9:23 PM
    #67
    Slodgetto
    Silas
    It'll be VERY close! :eek: Slapped several coats of Rustoleum Bedliner on the bumper tonight, and I'll hopefully get it on the truck in the morning before work.... Then it's all about getting in the front diff!!! skids and stuff will be last....
  8. May 2, 2012 at 11:13 PM
    #68
    Slodgetto
    Silas
    Bahaha. I may do that! :cool:
  9. May 3, 2012 at 5:38 AM
    #69
    Appljaxx
    Appljaxx This guy
    Jeremy
    Albuquerque, NM
    '18 TRD Pro
    Dont forget you will need time to learn how to drive with 4x4.. well not really, just use less throttle.
    Looks awesome. a new green monster.
  10. May 3, 2012 at 5:49 AM
    #70
    Slodgetto
    Silas
    Yeah, I know, man! I'm hoping to at least hit the Puerco once before heading to Moab!! :eek: Would be kinda funny and awesome if Moab is the maiden voyage after the 4x4 swap though. lol :eek:
  11. May 3, 2012 at 5:50 AM
    #71
    Appljaxx
    Appljaxx This guy
    Jeremy
    Albuquerque, NM
    '18 TRD Pro
    ill bring the champagne.
  12. May 3, 2012 at 5:54 AM
    #72
    Slodgetto
    Silas
    lol :cool: You'll have to drink it all though.... :pout: I can just squirt it everywhere :D
  13. May 3, 2012 at 5:55 AM
    #73
    Slodgetto
    Silas
    Dang, that comment could be twisted beyond belief^^^ :eek: :rofl:
  14. May 3, 2012 at 6:05 AM
    #74
    Appljaxx
    Appljaxx This guy
    Jeremy
    Albuquerque, NM
    '18 TRD Pro
    I KEEL YOU!!
  15. May 3, 2012 at 6:35 AM
    #75
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I aint drinking any if you're squirting it first!
  16. May 3, 2012 at 10:05 AM
    #76
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    Looking good buddy.
  17. May 3, 2012 at 9:09 PM
    #77
    Slodgetto
    Silas
    :rofl: :eek:
    Thanks, man. :)
  18. May 3, 2012 at 9:20 PM
    #78
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    :rofl:
  19. May 3, 2012 at 9:21 PM
    #79
    Slodgetto
    Silas
    :wink:
  20. May 3, 2012 at 9:22 PM
    #80
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    x2 on what ben said, if its not all done, hell we can finish it at camp! what a better place to find out of your 4x4 swap works than moab utah!
