Slop in Needle Bearing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AJKlug1, Sep 12, 2022.
  1. Sep 12, 2022 at 5:23 PM
    AJKlug1
    AJKlug1 [OP] Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Hi all,
    2010 Access Cab
    I was under my truck this evening tightening my cam bolts on the LCA's and I bumped into the CV axle on the driver side and noticed a fair amount of play. I know I read on here somewhere that on the driver side there is some extra play vs the pass side due to the needle bearing. I have been having a pulsating vibration that can be felt in the pedals and floorboard at 40mph and 60-70ish but the noise never went away in 4WD. I do have a 1" lift up front from the 3rd gen suspension swap. Is this too much play or is this normal for the driver side. I am not worried about the in and out but the up and down sloppiness. It seems like a little more than others I have seen. What are your thoughts? Thanks!
    https://youtu.be/I_55QLg3xP0
  2. Sep 12, 2022 at 5:33 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    More than mine but I got ECGS bushings and you got a 12 YO truck. I swapped mine because the seal was beginning to leak. If it bothers you and you got the time, money and technical skills, do it. Otherwise watch it and continue as you are.
    AJKlug1[OP] likes this.
  3. Sep 12, 2022 at 5:36 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  4. Sep 12, 2022 at 5:36 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    thanks, forgot to add the mileage(46,000) but yeah it still is 12 years old...
  5. Sep 12, 2022 at 5:37 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    TnShooter[QUOTED] likes this.
  6. Sep 13, 2022 at 11:07 PM
    Johnny DemonT
    Johnny DemonT Well-Known Member
    SW Burbs of Chicago
    15 Silver DCLB
    More than likely (99.9%) the sound is coming from your hub bearings if it does not go away in 4wd. The Needle bearing sound goes away in 4x4. Hub bearing noise will sound like a consistent slow vibration and is felt exactly how you describe it "pulsating vibration that can be felt in the pedals and floorboard at 40mph and 60-70ish." Even if you have minimal movement in your wheels when checking the play, the bearing are still most certainly bad. I wish I would have done mine 30,000 miles ago. These trucks eat hub bearing with any type of offset. I just did mine using this solution and highly recommend. very easy install. Moving forward, I will do these every 30,000 miles as the ride is like brand new:
    https://www.tacomaworld.com/threads/wheel-bearings-hubs-press-service-4x4-6-lug-2wd.537080/
    AJKlug1[QUOTED][OP] likes this.
  7. Sep 13, 2022 at 11:22 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I wouldn't worry about the axle. If it was flopping up and down more than normal, the first thing to go would be the seal. It's super clean and dry in that area. ecgs bushing has value but don't expect it to be tighter.
    Your noise is probably a bad wheel bearing in the front. Try this old school trick that works..
    -Lift the front wheels off the ground, spin each wheel while holding the knuckle. Any roughness felt through the knuckle is a bad wheel bearing. It should be quiet and smooth. Compare side to side. If one side is quiet and the other side is "louder", the loud side is the bad bearing.
    Remember putting a skateboard on your lap and replacing the bearings in the wheels? The old ones are loud and rough, the new ones are smooth. It's kinda like that, a car wheel bearing is just a big skateboard bearing
    AJKlug1[OP] and Johnny DemonT like this.
  8. Sep 14, 2022 at 3:40 AM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Thanks all!
  9. Sep 14, 2022 at 4:58 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    ECGS bushing has about the same amount of play.
  10. Sep 15, 2022 at 1:28 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    I put the ECGS bushing and new axle seals in when I did new NAPA CVs and it took most of the play out of that drivers side vs old needle bearing.
    Smoother at speed also (steering wheel vibration). Already had done the wheel bearings. 180k mileage.
  11. Sep 24, 2022 at 6:59 AM
    litterbox_racer
    litterbox_racer Member
    Nic
    2018 Tacoma turd
    If I could put Bones Swiss in the Taco…
    b_r_o[QUOTED] likes this.
