Sloppy shifter questions.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wildduk, Aug 18, 2025.
  1. Aug 18, 2025 at 5:11 AM
    wildduk
    wildduk [OP] New Member
    Timothy
    06 Tacoma
    New Tacoma owner here. Purchased 06’ 4x4 6spd manual for son’s first car. 137k miles seems solid so far. Shifter however is very sloppy. I’ve read all into it and watched the videos, but have a few questions.
    I want to go ahead and actually replace the shifter, as I don’t want to mess around with the epoxy, rubber fix…..assuming the stick is also worn.
    I assume he would also like the short throw mod, but I’ve heard this can lead to issues with the synchs in the transmission as it wasn’t designed to shift as fast???
    Don’t like the idea of the hurst, as it’s got no dampening.
    That leaves me with just buying a new stock shifter, assuming it would come with a new bushing. I’d not they are cheap…
    or, buying the TRD quick shifter, which looks like it comes with a new stick…..this option is assuming no issues with the synchs in the transmission……
    thx all.
  2. Aug 18, 2025 at 5:46 AM
    Clearwater Bill
    Billy
    Largo Florida
    Isn't there a simple bushing kit that replaces the worn parts?
    Seems like that would be step 1, before jumping into a shifter replacement.
    Note: this is from experience on another marquee, as well as casual reading here. Not actual Tacoma experience.
    Let us know what you find
    wilcam47 and TartanEagle like this.
  3. Aug 18, 2025 at 6:16 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I’ve had the TRD shifter on my ‘13 for ages. Probably 80K and over 10 years. I found it shifted better than stock with less grind going into 3rd.
  4. Aug 18, 2025 at 6:19 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    BigCarbonFootprint and scocar like this.
  5. Aug 18, 2025 at 8:32 AM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Those are a great place to start, and if he's pulling the shifter anyway he should definitely slap some new bushings in. However, being an '06, I'd say the bushing between the inner and outer shift stalks has failed. I'd put money on it.
    If you're looking for as close to stock with a shorter throw, get the TRD. It's expensive though.
    wilcam47[QUOTED] likes this.
  6. Aug 18, 2025 at 8:42 AM
    scocar
    scocar Patron of the Farts
  7. Aug 18, 2025 at 9:33 AM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    shaeff likes this.
  8. Aug 25, 2025 at 12:56 PM
    Greatwhite97
    Greatwhite97 Member
    2001 Toyota Tacoma
    I'm working on a 1992 Toyota pickup to change the shifter bushing. Attempting to push the cap down and counter-clockwise, and it's not budging going down.
    Any suggestions?
  9. Aug 25, 2025 at 1:20 PM
    Greatwhite97
    Greatwhite97 Member
    2001 Toyota Tacoma
    Just keep f'in pushing the mfer... got it
    goforbroke123 and scocar like this.
