Sloppy steering 2000 Tacoma Rack and pinion
Discussion in 'Technical Chat' started by mark530, Apr 28, 2012.
  1. Apr 28, 2012 at 9:10 PM
    mark530
    mark530 [OP] Member
    sr5
    I have a 2000 Tacoma 2wd and the steering seems sloppy it has 112.000
    on the truck and I have cked rack and pinion all is tight cked wheel bearings all is well it just steers sloppy compared to my 1986 Toyota pickup with 337000 miles on it is there something out there to help this steering
    Thanks Mark
  2. Apr 28, 2012 at 11:17 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Welcome to TW!
    Sloppy steering can be caused by a number of things including tires (e.g., uneven wear), lift (e.g., inability to obtain proper alignment), and steering rack bushings (e.g., worn out and "loose" feeling).
  3. Apr 29, 2012 at 3:02 AM
    mark530
    mark530 [OP] Member
    sr5
    I have a 2000 Tacoma with 112000 miles on it and the steering is sloppy
    I have cked wheel bearings and the rack and pinion is tight. Tire Pressure
    is at 30 psi . I have a 1986 Toyota pickup with 337000 miles on it and it has
    better steering control than my Tacoma. Any Ideas Thanks Mark
  4. Apr 29, 2012 at 3:10 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    there is a mod where you tack weld the steering column, I think there is more info on it on ttora. some searching there will find it im sure
  5. Apr 29, 2012 at 8:34 AM
    Norton
  6. May 26, 2012 at 12:19 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Inspect the inner/outer tie rods, ball joints and rack bushings. Go under the truck and have someone work the steering back and forth and look for sloppy things.
    The column slip joint on the inside near the firewall probably has lots of play. Its a safety feature to keep the column from sliding up in a crash. mine has lots of play, and I haven't tried to fix it.
  7. May 27, 2012 at 6:45 AM
    mark530
    mark530 [OP] Member
    sr5
    Thanks for the info I will ck it out Mark
