Sloppy steering?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trr-ey, Feb 27, 2023.
  1. Feb 27, 2023 at 7:56 AM
    Trr-ey
    Trr-ey [OP] Member
    Trey
    2010 Toyota Tacoma
    2 inch lift
    Hey everyone got a question, steering has been sloppy since day one, I have replaced everything on the dam truck. It’s sloppy on and off-road I’ve replace the upper and lower steering shaft, the upper shaft has play in it, put a zip in there and still feels the same, bottom shaft is aftermarket wondering maybe that could be the reason? Rack has been replaced, suspension, lca, uca has been replaced. Only thing I can think of also is the couldn’t get my toe in the green So I have a bit of toe in at the moment, possibly from a slight bent spindle. Currently on 35’s but been a problem since 31’s.
  2. Feb 27, 2023 at 2:15 PM
    taco912
    taco912 Well-Known Member
    North of the Bridge
    2006 AC 4.0 AT 4x4 SR5 TRD OR
    When I replaced all the wear parts on the front end at 135K, the most worn of all the parts were the inner tie rods. I didn't see inner and outer tie rods on your replacement list. You must have as you did the rack.
  3. Feb 27, 2023 at 2:25 PM
    gtrotter07
    gtrotter07 Well-Known Member
    2007 Tacoma reg cab 4x4 on 37's; 2021 TRD Offroad, 6 speed
    37's,lockers, bumpers, bobbed etc.
    Check torque on the rack bolts? Mine loosened up after a rack replacement and needed re torqued.
  4. Feb 27, 2023 at 5:25 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    When you're driving straight, down the highway. Do you ever notice your steering wheel being 'off' from what it was the day before, or the week before? If I recall from what I've read here, a shifting steering rack will present like this, like something is shifting around.
    Trr-ey[OP] likes this.
  5. Feb 27, 2023 at 7:40 PM
    Trr-ey
    Trr-ey [OP] Member
    Trey
    2010 Toyota Tacoma
    2 inch lift
    My steering has been cock eyed to the right for awhile now, i don’t notice any shifting now but my old rack was like that
  6. Feb 27, 2023 at 7:40 PM
    Trr-ey
    Trr-ey [OP] Member
    Trey
    2010 Toyota Tacoma
    2 inch lift
    I’ll defiantly check them
  7. Feb 27, 2023 at 7:40 PM
    Trr-ey
    Trr-ey [OP] Member
    Trey
    2010 Toyota Tacoma
    2 inch lift
    Yeah inner tie rods brand new outter tie rods same it’s so weird
