Sloshing in dash and coolant not returning to radiator from overflow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremyk61, Sep 15, 2014.
  1. Dec 15, 2014 at 8:06 AM
    #61
    Polonia
    Polonia Member
    tom
    niagara falls
    tacoma TRD
    borla exhaust
    Here is an update on the head gaskets that I replaced.
    My leak was occuring on cylinder 4 and 6. I guess alot of failures are happening there.
    when the gaskets were pulled I could see where it was leaking.
    symptoms were:
    gurgling coolant in the heater core while accelerating
    slight sweet smell from exhaust
    spark plugs 4 and 6 were slighty different than the others, whitish deposits
    doing a vacuum check on the coolant system. It was not holding vacuum and you could hear gurling in the block...
    toyota head gasket kit $220
    head bolts $180
    machining heads $225 machined .006"
    and a few other tools and parts..
    I have a 175k miles and It should be good for another 100k miles
    In conclusion if you cant fix it yourself, put your seat belt on and check the air bags..
    tomtigger likes this.
  2. Dec 17, 2014 at 11:28 AM
    #62
    SeaThruLens
    SeaThruLens Veteran Lurker
    Bill
    Stuart, Florida
    08, TRD Sport
    Sub'd. At 178k and after reading this thread I think i hear this noise.
  3. Dec 22, 2014 at 6:30 PM
    #63
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    subbed, i'm at 175k and I think I heard this noise yesterday.
  4. Dec 31, 2021 at 12:07 PM
    #64
    Maswinter
    Maswinter New Member
    Michael
    4cyl tacoma 375000
    None
    O7 tacoma 4cyl...368000... Same problem I guess after listening to you guys I should assume head gasket as well
  5. Dec 31, 2021 at 12:13 PM
    #65
    Maswinter
    Michael
    4cyl tacoma 375000
    None
    So being that I don't have 3 or $4000 to have the head gasket replace what's wrong with pouring in the radiator substitute to seal the head gasket
