Sloshing sound behind dash again
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrcheap, Mar 14, 2021.
  1. Mar 14, 2021 at 7:46 AM
    mrcheap
    mrcheap [OP] Well-Known Member
    I know there are a bunch of posts and I have already started trouble shooting.
    1. ran the truck with the rad cap off to burp the system but coolant looks good and full and zero bubbles came out. No coolant leaks anywhere and the color is good.
    2. heater core issue - not sure where to start
    3. ac drain issue - not sure where to start
    4. head gasket issue - it’s an 05 4.0 so I know I’m at risk
    no water on the floor and vehicle runs fine. Sloshing goes away after driving awhile. I do drive the vehicle only once a week.
  2. Mar 14, 2021 at 9:26 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    How does it start when it's cold, 1st start of the day, or after work...? Does it stumble for a second it 3, then smooth out?
    If so, then I got some not so good news...
    Sloshing... As in what it would sound like if it were a bucket of water? On the passenger side floor area. Or the sound of water and air running through a pipe? Right in front of you in the dash. More of a gurgling sound... This was and the cold start stumble, were my symptoms for needing a head gasket.
    Know any HVAC guys? Ask one for a long wide tyrap. Push that up through the AC drain. If there's any water up there, pushing in 12" or so it'll be coming out
  3. Mar 14, 2021 at 9:27 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    A/C drain is under the hood on the passenger side (the small rubber hose sticking thru the firewall), turn the blower on high and put your hand in front of it, there should be air coming out of it, it theres not it's likely plugged.
    SR-71A likes this.
  4. Mar 14, 2021 at 9:29 AM
    mrcheap
    Vehicle starts right up, no stumbling, runs normal.
    The sloshing doesn’t sound like a ton of water and happens a few times especially on some hard accelerations. Then goes away. I need to do more research on the heater core and ac
  5. Mar 14, 2021 at 9:45 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Too get the heater core out,the entire dash has to be pulled apart a major job,so hopefully that's not the problem.Head gasket job $$$$.
  6. Mar 14, 2021 at 9:51 AM
    mrcheap
    Can it be flushed? Think I saw some links and vids.
  7. Mar 14, 2021 at 12:19 PM
    Larzzzz
    Larry
    MA
    The v6 has connections best the fire wall on the drivers side up high.
    On the passenger side, much lower, you'll see something sticking out of the firewall maybe an inch. That should be the drain.
  8. Mar 28, 2021 at 9:21 AM
    mrcheap
    Update on this
    I burped the system by basically running it with the rad cap off - 0 air bubbles and squeezed the top hose
    checked the ac drain line and blew some compressed air and does not appear clogged or anything. No wet floor mats etc
    I am at a loss on what to do next.....truck fines fine with no, smoke or cel but still that darn sloshing sound
    should I do a full coolant flush?
    thanks
  9. Mar 28, 2021 at 9:30 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Fill the tank and remove the half finished soda bottle from under the seat.
  10. Mar 28, 2021 at 10:07 AM
    mrcheap
    Gas tank? Nope it’s full and nothing under the seats :)
    SR-71A likes this.
  11. Mar 28, 2021 at 8:14 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    All the good suggestions were taken.
  12. Mar 28, 2021 at 8:17 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Have you looked under the cowl below the wipers? That’s where ventilation air comes from. It’s a big enough space to fit a half finished soda bottle.
  13. Mar 28, 2021 at 10:34 PM
    avery0829
    avery0829 Well-Known Member
    Western Washington
    2005 Tacoma DCLB Sport
    Bilstein 5100, Trail edition wheels, 265/70/17 Falkens
    Do a Blackstone oil analysis on next oil change?
  14. Mar 29, 2021 at 4:33 AM
    Larzzzz
    Larry
    MA
    Where exactly, do you localize it when you hear it? In front of you.... Up high, down low, passenger side?
    Got a HVAC friend? Ask him for a 3' tyrap. It's wide enough and stiff enough to push through the drain on the passenger side.
    I heard water sloshing on the passenger passenger side. The tyrap fixed that.
    I heard what sounded like water running through a pipe with air in it. Pretty much right in front of me while driving. If you have forced hot water heating, you've probably heard that sound. That was fixed by swapping the motor.
  15. Mar 29, 2021 at 4:35 AM
    mrcheap
    By motor you mean engine? Lol
  16. Mar 29, 2021 at 4:35 AM
    Larzzzz
    Larry
    MA
    Sadly that's what I meant.
  17. Mar 29, 2021 at 5:11 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Does the heat work in the truck if you turn it on full hot?
  18. Mar 29, 2021 at 8:19 AM
    mrcheap
    heat works fine
  19. Mar 29, 2021 at 8:43 AM
    azgunrunner
    azgunrunner A guy that knows a guy, that knows a guy...
    George
    Arizona
    06 DCLB Sport
    ADS 2.5, Dakar leaf springs KMF sliders CBI Ditch light mounts, DD SS3 pods Bumpers pending OBA pending
    I'm not sure when I started noticing it, might have been happening all along, but over the last year or so I've noticed that when I start my truck too. I can hear water/liquid moving. Almost like it's coming from behind the dash, perhaps the header core is filling up or something. Sound goes away after a min or two. No leaks inside the truck, coolant levels are fine, no bubbles in the coolant, truck runs fine.
  20. Mar 29, 2021 at 8:43 AM
    azgunrunner
    George
    Arizona
    06 DCLB Sport
    I did a coolant flush and it still does it....
