Sloshing sound behind dash again
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrcheap, Mar 14, 2021.
  1. Mar 29, 2021 at 8:56 AM
    SigmaEOD
    SigmaEOD Screaming Goat
    Alex
    Overland Park
    2007 TRD Offroad
    Same Issue here as well, 07' 4.0L V6. Not sure what it is, It almost sounds like coolant flowing through the system for the first time
    azgunrunner likes this.
  2. Mar 29, 2021 at 8:59 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Did you run the heater core while doing the coolant change? Maybe there was air in the heater core/heater core lines even though when you burped the system and no air bubbles came out. Then when you're running the truck the coolant is flowing in/out of the heater core causing the noise. Just a thought.
    SR-71A likes this.
  3. Apr 4, 2021 at 6:32 PM
    kernel_panic
    kernel_panic New Member
    2006 2.7 2TR-FE
    I'm also hearing some sloshing right behind the dash when accelerating in my 2006 2.7
    Going to do a full coolant flush and replace once the order arrives. About the head gasket leak, can't you test that with a combustion leak tester?
