Slotted Rotors Warpped
Discussion in 'Performance and Tuning' started by WV_Tacoma, Jul 20, 2009.
  1. Jul 20, 2009 at 12:07 PM
    WV_Tacoma
    WV_Tacoma [OP] Well-Known Member
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    Anyone with Slotted rotors ever warp them? If so what kind, were they cyro treated?
    What is the best pads? All I hear is Ceramic but why....
    thanks
  2. Jul 20, 2009 at 12:24 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    For Pads I say Hawks.
  3. Jul 20, 2009 at 1:04 PM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    What about the Rear Drum breaks......
    Should attention be given to them like;
    Adjustments since new rotors/pads in frnt?
    Should you install new lines for rear since frnt are new?
    What about rear pads-Ceramic as well?
    Thanks Guys
  4. Jul 20, 2009 at 2:01 PM
    Brunes
    Brunes abides.
    Rotorhead
    Yes- The rears need the attention. Clean and Adjust them at a minimum...Wear in general requires they at least be looked at every 15-20K imo. Replace the pads with a good pad (Hawk all the way around is not a horrible idea) if you want.
    They don't NEED new lines but if you've lifted the rear and off road regularly, extended lines are a good idea.
    Make sure to bleed all the way around to make sure any air trapped is pushed out...
