Slow Coolant Leak on 2.7L 4x4 Getting Worse
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kilokato, Dec 24, 2015.
  1. Dec 24, 2015 at 11:22 AM
    Kilokato
    Kilokato [OP] Go Vols!
    George
    East Tennessee
    2016 SR5 Access Cab V6 Auto 4wd
    Limited wheels, extra rope hooks in bed.
    Hey Guys, I have a 1997 4x4 5-speed manual with 250,000 miles. It has the 2.7 engine. I have been having a slow coolant leak for a year or more that just seems to get worse. There is no puddle or spray on the engine or anything obvious. The oil is fine. Truck runs smooth. Gas mileage is close to 25 mpg. I can't seem to figure where my anti-freeze is going. Original water pump also. No over heating problems. I did replace the radiator about 15,000 miles ago but I had the problem even before. Again, no wet spots from anti-freeze anywhere I can find.
    Thanks in advance for any advice!
  2. Dec 24, 2015 at 11:36 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I bet its weeping from your waterpump, drying before it drips. take a look at the weep hole and your should see a stain.
  3. Dec 24, 2015 at 2:19 PM
    razornpc
    razornpc Member
    iowa
    2001 Prerunner
    theres a pipe plug on the passenger side of the block that ive had rattle loose on me before. itll dribble and never leave a puddle too.
    if its an original water pump my money is on that though.
  4. Dec 24, 2015 at 2:24 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    Itll also drip and not puddle if leaking from the thermostat housing
  5. Dec 24, 2015 at 2:41 PM
    Exhaust
    Exhaust Well-Known Member
    Erik
    Wharton State Forest
    02 DC TRD
    Extended breather, Grey Wire mod, Tundra brakes, Rockford-Fosgate sound, General Spring HDs, 5100s + 880s, Heated Seats, TRD Supercharger, 2.1 Pulley, URD 7th Kit
    If your radiator cap is bad it won't seal and you will lose coolant/water as steam
  6. Dec 24, 2015 at 2:41 PM
    Clearwater Bill
    Billy
    Largo Florida
    Borrow a pressure tester from a parts house that has a tool loaner program. Simple and accurate.
  7. Dec 25, 2015 at 4:32 AM
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    How is your truck when you start it when it's cold. My Tacoma (2.7) would hesitate ever so slightly then smooth out on cold starts. My coolant overflow tank was also low. No other indications of head gasket. No milky oil or white smoke etc...turns out. Head gasket! Had about 200k when it went out. Also these radiators have plastic end caps. Check to see if there's a leak anywhere. If you don't see any leaks then I would do a pressure test like Clearwater Bill said.
  8. Jan 16, 2016 at 5:38 AM
    Kilokato
    George
    East Tennessee
    I bought a water pump and tore it down to replace it but after taking the belts off I got a mirror and looked for stains from the weep hole. No stains at all. It will occasionally steam when I turn it off but the last time it did I wasn't in a position to look at it very well. Runs great and no oil in the water. I don't think the exhaust is an whiter than normal. Can't find any leaks in hoses. Replaced radiator last year so it's good.
