Slow Cruise Control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by choprpilot76, Dec 10, 2010.
  1. Dec 10, 2010 at 7:10 PM
    choprpilot76
    choprpilot76 [OP] choprpilot76
    Fort Irwin, CA
    05 Tacoma 4WD DC LB
    UDR Fuel Pump and Filter
    I just bought a used 2005 Taco (4x4 Long Bed, Double Cab). From the get go I noticed that the cruise control is extremely slow to engage and react. I have owned several vehicles in my life and none of them have ever had this problem. Normally when you engage cruise it takes over immediately and you can take your foot off the pedal. In this truck if I hit the set button on the cruise control and take my foot off the gas the truck slows just as it is supposed to, and takes a good fives seconds to react and respond and rev the RPM's and downshift to speed it back up to the speed I selected. The same problem exist when climbing a hill, the vehicle will slow way down and it will take well over 5-10 seconds almost before it drops gears and gives it gas. Does anyone else experience this, I am sure this isn't normal for all of your Tacomas? Does anyone have any suggestions on what it might be or what I can try to fix it? The fuel pump and filter are fine. The vehicle is not under warranty anymore, so the I will do the work myself. Thanks for an help. Daron
  2. Dec 11, 2010 at 7:29 AM
    JKD
    JKD Well-Known Member
    I assume there is no hesitation when you manually depress the gas -- it goes immediately, right?
  3. Dec 11, 2010 at 7:42 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    I don't know about 5 seconds, but there is definitely a delay.
  4. Dec 11, 2010 at 7:45 AM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    Red Prerunner AC
    CC is VERY lame. I rarely use it.
  5. Dec 11, 2010 at 7:51 AM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    Have you ever had a car with fly by wire before, The difference between a cable and the electronic throttle might be why it feels different. I use the cc control a lot, it is fine.
  6. Dec 11, 2010 at 10:27 AM
    choprpilot76
    Fort Irwin, CA
    05 Tacoma 4WD DC LB
    No there isn't any hesitation when I press it. The CC is a very bad delay, I have to believe way worse than a new Tacoma would be, if at all.
  7. Dec 11, 2010 at 10:49 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    07 DCSB Sport 2wd
    5100s @ 0.85, Grom iPod/Bluetooth adapter, mud flaps removed, clear turn signal bulbs, two extra D-rings, debadged, fog light anytime, OEM bed mat, Undercover classic, Falken Wildpeak A/T3W, Fumoto valve
    I say get used to it man. The CC in these trucks is garbage compared to other vehicles I've driven. One thing I've started doing is when I know there is a hill coming up that I know it will slow down and lag too much I'll step the gas just a little at the beginning of the hill to help it along at first.
  8. Dec 11, 2010 at 10:53 AM
    choprpilot76
    Fort Irwin, CA
    05 Tacoma 4WD DC LB
    Well I am about to replace the spark plugs which I have a feeling have not been done in a loooong time, so we'll see if that does anything for the performance.
  9. Dec 11, 2010 at 12:39 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Mine seems slow also and not nearly as responsive as my husbands Acura. I have to hold the stock up/down for atleast a second before it'll register. And yes....I get the same type of delay when it slowing down/etc. I find myself bliping the increase button a lot.
  10. Dec 11, 2010 at 12:42 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    i never use cc. im gonna try it out and see if mine does the same
  11. Dec 11, 2010 at 12:45 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    there is a slight delay on mine, but not 5 seconds though.
  12. Dec 11, 2010 at 1:28 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    well, mine hesitated for a second, but it dosnt bother me since a never use it.
  13. Dec 11, 2010 at 1:29 PM
    SilverTacoZack
    SilverTacoZack Well-Known Member
    Zack
    Elgin, SC
    2011 FJ trail teams
    Hmm....mine doesn't hesitate at all. I've found the Tacoma CC to be just as good as the CC in my BMW e46 that I drove before this.
  14. Dec 11, 2010 at 2:54 PM
    pinktaco808
    pinktaco808 Hot Steppa
  15. Dec 11, 2010 at 3:10 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    I too have de delay like any other tacoma. My guess is they added the delay for safety reasons (ex: someone use CC when it's raining, then start hydroplanning: the CC won't try to compensate for the speed variation right away, thus not getting you in the ditch)
  16. Dec 11, 2010 at 3:16 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    i feel the same. it's about as responsive as what i had in my mazdaspeed3 and what my wife has in her Si. i have no issues with it and truthfully i always use CC.
    OP, i'm curious to see what anyone else has to add regarding your particular issue.
  17. Dec 11, 2010 at 4:01 PM
    choprpilot76
    Fort Irwin, CA
    05 Tacoma 4WD DC LB
    see, that's my whole point, compared to any other vehicle it's slow, because like many of you all said about your other makes, they work fine. I use my CC all the time, it's not the end of the world but it's just annoying, so if there was something to try to fix I would, but if not, then I guess I am SOL. Thanks.
  18. Dec 11, 2010 at 6:32 PM
    Rob H
    Rob H Active Member
    The CC is not great on my Taco.. 06DC4x4. It really reacts slow going up slight hills, then guns it to catch back up to the set speed (~70). :( I have gotten used to it and turn it off on grades...
  19. Dec 11, 2010 at 8:09 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    debadged, rear spring TSB, leveled with Bilstein 5100s at 1.75", Goodyear Duratrac 265/75/r16, Leer shell with Yakima rack
    Mine delays as well, then overshoots when it's trying to come up to speed. Set at 65, it'll slow to 60 up a hill, then go all the way to 70 after the crest. I think that's just the way it is.....
  20. Dec 13, 2010 at 1:22 AM
    MajKong
    MajKong Well-Known Member
    Johnny
    Reno, NV
    2008 4X4 Access Cab 4cyl
    Seatbelt Buzzer turned off, Bed Mat, Illuminated 4X4 switch, Intermittent Wipers, Fumoto drain valve, LCE header, fog lights
    My cruise control works just fine and I use it all the time, even crossing the Sierra Nevada Mountains. I have a manual transmission, perhaps the lag has to do with the automatic transmissions.
