Slow Fuel Gauge
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TexasWhiteIce, Jan 27, 2018.
  1. Jan 27, 2018 at 9:50 AM
    TexasWhiteIce
    TexasWhiteIce [OP] Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    So after 8 years of this mystery, I’ve finally figured it out.
    I’ve always had a habit of never letting my gas tank go below a 1/2 tank. So I tend to fill up between 3/4 and 1/2 tank. Over the years, I’ve notice that sometimes when I fill up my tank, the fuel gauge is very slow in reading full, while at other times it show full right away when I start the truck.
    I’ve finally noticed that whenever I fill up the tank anytime below 3/4 tank, the fuel gauge registers full right away, but if I fill up anything above 3/4 tank, it is slow to register full. Normally takes about 5 miles to finally register full.
    It’s been like this for 8 years now ever since I bought the truck new and it always confused me. I’ve always been afraid something was wrong, but since it’s been 8 years and I haven’t had a problem with the truck, I guess this is just a characteristic of the gauge. Just thought I’d share. Don’t know if this occurs for everyone, but it always occurs for my truck now that I know what condition causes this.
  2. Jan 27, 2018 at 10:05 AM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    Mine doesn’t do that, but it will stay above full for 50+ miles. It also drops slowly through the first quarter tank, then it’s almost as if you can see it dropping after that. It’s not proportional at all, but I’ve got it figured out.
  3. Jan 27, 2018 at 10:33 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Mine just shows whatever I put in right away. Half, 3/4, or full. Might be something goofy with the float or sending unit. Clearly it isnt hurting anything though.
  4. Aug 22, 2018 at 10:08 PM
    Skittles93
    Skittles93 'Member
    Novato CA
    TRD OR SB 4x4 (sold) 19 4runner TRD Pro
    Frankenstein Mid-Travel Kit, sPod, Relentless Custom Baja Bumper, Relentless: Sliders, T-case skid, rear bumper, tailgate reinforcement, Rago Fab: Bed Channel Stiffeners, SCS 16" wheels, BFG KO2 275,75,R16, Diff breather mod, A/C hose extension mod, Custom exhaust routing. (Sold)
    Wow I just noticed that today when I filled up from 7/8ths tank to full (4 gallons). Not sure if it’s a bad fuel sending unit or just the cars character?
  5. Aug 22, 2018 at 10:13 PM
    stomachbuzz
    stomachbuzz Well-Known Member
    Silver Spring, MD
    2005 V6 6spd!
    Happened with my old 2nd gen too!
  6. Aug 23, 2018 at 12:44 AM
    HillJackJDS
    HillJackJDS Well-Known Member
    Dale
    2008 Tacoma 4WD
    I would like to wean mine off of fuel altogether...so far no luck...
    The float runs a rheostat basically. If it fails to float 100% "high and dry" or pivot freely then you will see slow response. In the case where tank remains "full" for while longer than you think it probably, should, the range limits for the gauge are just hit... No biggie either way once you know they are there--just play accordingly.
    Getting used to this situation (not pronounced "problem" at all) will save you lots of money.
    Now, if it registered 1/2 and you go empty, then that is a potential problem.
  7. Aug 23, 2018 at 4:57 AM
    Stillwell-Taco
    Stillwell-Taco Well-Known Member
    06 sr5 trd prerunner
    Piss on it until the light comes on
  8. Aug 23, 2018 at 6:44 AM
    stomachbuzz
    Silver Spring, MD
    2005 V6 6spd!
    :yes:
  9. Aug 23, 2018 at 8:37 AM
    vtdog
    vtdog Well-Known Member
    NH
    Put a few Adderall tabs in the take to wake it up
  10. Aug 23, 2018 at 9:13 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    its slow for you to get it up the last part because of the dampener in the cluster assy and the very little voltage difference
    empty tank makes it break past that dampener stickiness and gets it up quicker
  11. Aug 23, 2018 at 9:22 AM
    stomachbuzz
    Silver Spring, MD
    2005 V6 6spd!
    Basically, it happened to me the first time after I filled it up from sitting for a long time. It had been like 2-3 months since it had been driven, and no idea when the last fill up was.
    The gauge went down just fine, but coming back up it took like 20 mins to show a full tank.
    The next tank was fine though
    probably just a tiny bit of corrosion or friction
  12. Jun 27, 2019 at 4:23 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I know this is an old thread, but this came about from searching.
    Same thing happened to me today. I thought something was wrong with my float or my gauge...or maybe the pump clicked off too early. I was topping my truck off for what's planned to be a lot of driving from Friday to Sunday. I was about 5 gallons down from full, so I filled up and gauge needle didn't instantly pop back up as usual. 5 miles later and the needle slowly crept back up to full.
    Based off of your post, it seems normal (unless you found something after this thread) and just something to keep in mind if filling the tank from 3/4 or more to full.
  13. Jun 27, 2019 at 5:51 PM
    TexasWhiteIce
    Texas
    Nope, this is exactly what happens. It’s like clockwork, happens every single time under those conditions
  14. Jun 27, 2019 at 6:06 PM
    FishingPups
    FishingPups Well-Known Member
    Barry
    2014 Tacoma TRD Sport Access Cab
    Prerunner, Towing Package, Convenience Package, Tonneau Cover
    My Ford did strange crap like that until I got the fuel pump replaced. My drive way is about a 30 degree downhill slope. On a full tank, with the front end pointed down the driveway you could start it up in the winter time to warm it up and the longer it sat there the needle just kept dropping until it pointed to empty. Pull it out of the drive way and start driving it down the road and the needle would slowly creep back up to full.
  15. Jun 28, 2019 at 3:57 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    People with this type of problem have seen improvement, in some vehicles, by using Marvel Mystery Oil in the gas at the rate of 4 oz. to a tank of gas. If it is a sticky or corroded sensor it can help and won't hurt anything. It may take a tank or two to see effects. We had a '15 Forester that would not read full after filling up with the ignition key on (listening to radio for instance). It was some factory glitch that the dealer new about. Key off, it would fill and read fine.
  16. Jan 2, 2025 at 10:24 PM
    jspec rsx
    jspec rsx Well-Known Member
    I realize this is an old thread, but this just happend to my 09, tank had a little above 3/4 tank full and filled up. Took about 5 miles to get to full mark, this was the 1st time it happened to me. Was the issue found, or has anyone else had this issue happen before?
  17. Jan 3, 2025 at 5:46 AM
    hdn4space
    hdn4space Well-Known Member
    FL
    2013 Silver SR5 4x4
    my 2013 does this occasionally, maybe a couple times a year. never really paid much attention. next time i will.
