Slow leak driving me slowly insane!
Discussion in 'Wheels & Tires' started by BigRed75, Sep 23, 2008.
  1. Sep 23, 2008 at 2:22 PM
    BigRed75
    BigRed75 [OP] Active Member
    AL
    2012 PreRunner SR5 Barcelona Red Metallic
    Sat. before last, some jerk cut me off & to avoid him slamming into my kid in the back seat, I swerved & hit the curb with the right rear tire. It has a very faint scrub mark but that's it. Mon., just 2 days later, the tire was almost completely flat, so on went the spare until I could get to the shop. At the shop Sat., the guys filled it up, ran tests, & found absolutely nothing wrong with it. They told me to just watch it & if it did it again, bring it back. All was well & good until, you guessed it, this Mon. AM, the tire was flat again. So, hubby aired it up & I drove it over to the shop again. This time, they dismantled the tire, ran all their tests again, & again found nothing wrong with it - they put it back on & I drove home. Tue., the tire looked fine. Today (Wed.), it's low enough that it'll definitely be flat tomorrow morning. What's going on? I can't keep missing work to spend 2hrs. at the shop for "nothing"?? ARGH!!
  2. Sep 23, 2008 at 2:31 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    If you literally slammed into the curb you might have dented the wheel slightly creating a small gap between the tire and wheel. But I'm probably wrong.
  3. Sep 23, 2008 at 2:34 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Yeah definately check your rim, tire can look perfect but its always your rim you got to watch out for.
  4. Sep 23, 2008 at 2:39 PM
    BigRed75
    AL
    After I mentioned to them that when I had this issue years ago on my '85 S10 it was due to a dented rim, they checked both rim & tire & still didn't find anything wrong.
    *sigh*, I guess only a new rim & tire is going to solve this problem. :(
  5. Sep 23, 2008 at 2:42 PM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    Have they checked the valve stem? Thats the only other thing it could be.
  6. Sep 23, 2008 at 2:45 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    Does the tire pressure gauge lights on the board??
  7. Sep 23, 2008 at 2:47 PM
    BigRed75
    AL
  8. Sep 23, 2008 at 2:48 PM
    BigRed75
    AL
    Yes, and the tire itself is visibly low.
  9. Sep 23, 2008 at 2:52 PM
    eordonez
    Ed
    Chihuahua, Mexico
    well my guess it could be the wheel and the valve stem, or even sometimes the tire can have a small crack not imperceptible to the eye, why don't you try this: have your spare tire swapped on your damaged wheel, and viceversa, that way you can see which one is damaged the wheel or the tire,,,
  10. Sep 23, 2008 at 3:08 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I hope you don't have to replace it! A new OEM wheel is about $475.
  11. Sep 23, 2008 at 3:19 PM
    BigRed75
    AL
    Hmm, that's a good idea.
    Thanks!
  12. Sep 23, 2008 at 3:21 PM
    BigRed75
    AL
    Yeah, so far, I haven't been out of pocket on anything & it would be nice to keep it that way, lol.
  13. Sep 23, 2008 at 3:24 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you had a bent rim enough to cause you to lose air - you'd see it and you'd most likely have vibrations also.
    Did you actually watch the shop take the wheel off the rim and check it?
    Did they clean the rim and clean the tire surface?
    Here's something to check - Take the tire off & fill it up. Pour some soapy water over it (all over it). Watch for air bubbles forming. You could have a very slight crack in the rubber/sidewall from the impact, enough to cause a slow leak.
  14. Sep 23, 2008 at 3:39 PM
    BigRed75
    AL
    I definitely don't see a dent or feel vibrations - on my old S10, I *knew* I bent the rim immediately, but this time, I didn't hit the curb nearly that hard.
    Yes, I saw them do the whole thing, including cleaning the rim & tire (I was standing in the shop area rather than in the waiting area, discussing football with one of the guys who was on break).
    I definitely think it's worth a shot giving it a test myself, though, to see whether I notice anything the shop might've missed.
  15. Sep 23, 2008 at 3:57 PM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Yeah, do as she suggests. Its the easiest way to detect a leak but pump up the tire pressure to the maximum pressure indicated on the tire. You'll detect the leak sooner since its a very slow leak. If you dont have luck with the soap test, drop your tire in a tub filled with water and remember to do the soap test on both sides. If nothing helps, as a last resort you may consider using a liquid tire sealant. Good luck.
  16. Sep 23, 2008 at 4:04 PM
    BigRed75
    AL
    Thanks.
  17. Sep 23, 2008 at 4:06 PM
    eordonez
    Ed
    Chihuahua, Mexico
    hope is an easy cheap fix! good luck!
  18. Sep 29, 2008 at 3:31 PM
    BigRed75
    AL
    Well, after a dip test showed the hole,:rolleyes: I've now got a new tire plus a free oil change coupon for the hassle.
    I'm a much happier camper now. :D
    Thanks for all the advice! :)
  19. Sep 29, 2008 at 5:12 PM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    Wow...sounds like my front passenger tire right now. Drove slowly (in a parking lot) into a deep pothole/rut and the pressure in that tire started to drop. Didn't see the pothole. I noticed the tire was bulging a few days back and found out it was at 25psi.
    How much did you have to pay to replace the tire?
    My tire is only two weeks old...hope I can get it replaced without having to pay out of pocket.
  20. Oct 6, 2008 at 2:12 PM
    BigRed75
    AL
    I'm sure I probably could've done better had I shopped around for the tire, but I was just so sick of waiting at shops and all that I just replaced it with the same as what I had on it, so it was $144.95 when all was said and done.
