Slow leak repair? (6MT Fill Plug)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kasbien, Mar 23, 2016.
  1. Mar 23, 2016 at 6:08 PM
    Kasbien
    Kasbien [OP] Well-Known Member
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Pop rivets and JB Weld.
    Changed out my manual transmission fluid last summer and replaced the fill plug/crush washer as well. It's had a super slow leak from the fill plug since a month or two after the change and I finally want to do something about it.
    Best remedy? Not really sure what sealants I can use when dealing with gear oil.
  2. Mar 23, 2016 at 7:43 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    I don't think there should be fluid above the fill port if the quantity is correct. I'd remove the fill plug, allowing any trans. fluid to drain out, wipe the area around the fill port clean, then replace the crush washer and torque the fill plug to spec.
    Good luck.
  3. Mar 23, 2016 at 7:58 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    There shouldn't be any fluid resting above the fill port. But the bonus of a fill port is that the device itself is very hard to over fill. I'd remove the plug and gently clean the threads of both the plug and trans case, put on a new crush washer and a light coating of RTV. Torque to spec and you're GTG
  4. Mar 24, 2016 at 6:49 AM
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    I hadn't thought about the potential for overfilling it... Thanks guys, I'll try a new washer and some rtv this afternoon.
    Hardscrabble likes this.
  5. Mar 24, 2016 at 5:07 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    I would also check the breather hose, make sure it isnt clogged. On my 4 cyl, it is run up to the engine compartment next to the front differential breather hose.
  6. Mar 24, 2016 at 6:26 PM
    Jason J
    Jason J Well-Known Member
    oregon
    08 tacoma 4x4
    Your transmission shouldn't have a crush washer on the fill or drain plug. It should have a flat aluminum washer on both plugs.
  7. Mar 25, 2016 at 7:30 PM
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Okay, so maybe my driveway isn't as flat as I thought (when I did the initial change). Pulled into the garage and a decent amount dripped out when I pulled the fill plug. Afterwards, I tilted the truck a bit to one side to keep anymore oil from getting on the clean threads. This way I could ensure that the RTV would set properly. A dab of RTV on the threads and a new washer and Bob appears to be my Uncle! Went wheeling today and it still looked dry by the time I got home.
    Thanks guys!
