Slow, low RPM hill climb. WTF?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by UplandTaco, Oct 15, 2019.
  1. Oct 15, 2019 at 7:46 PM
    UplandTaco
    UplandTaco [OP] Well-Known Member
    I was driving in the mountains recently and went to climb a pretty steep hill in 4hi.
    The RPMs were ~1000 and the truck was moving incredibly slowly even with my foot pushed all the way to the floor.
    Has anyone experienced this before? Are our trucks really that weak?
  2. Oct 15, 2019 at 8:56 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Doesn't sound normal, but then again I don't know all the facts here. Details about your truck would help, like trim, engine, auto or manual...
  3. Oct 15, 2019 at 8:58 PM
    Bishop84
    Bishop84 Well-Known Member
    What speeds? Offroading or highway?
    When I sense any kind of lugging I always slap it into sport mode S4 and let the motor do its thing.
    If this is offroading, 4Lo is the answer.
    Hobbs and shakerhood like this.
  4. Oct 15, 2019 at 8:59 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    If AT and you were flooring it, then not normal for sure. If MT and flooring in 4th up the hill, you are in the wrong gear. Good luck.
    Comb, SR-71A, Dryfly24 and 7 others like this.
  5. Oct 16, 2019 at 4:37 AM
    Mojlnir
    Mojlnir Well-Known Member
    Parker, CO
    2018 SR ACLB Utility Pkg
    The trucks have plenty of power....they're just geared for flat land fuel economy.
    Regear.
  6. Oct 16, 2019 at 4:43 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    If offroad, it sounds to me like traction control was kicking on limiting throttle input to control wheel slip.
  7. Oct 16, 2019 at 4:49 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    We're you getting any traction control lights?
    Chew likes this.
  8. Oct 16, 2019 at 4:50 AM
    Travelinman301
    Travelinman301 4 x 4 Fanatic
    Florida
    2018 Blazing Blue Pearl Tacoma TRD Sport 4 x 4 DCSB
    KDMAX-PRO-10.0 Diode Dynamics Sport Fog Lights Morimoto Clear Tail Lights TRD Skid Plate
    X2
  9. Oct 16, 2019 at 4:52 AM
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    Yes this as well 4 lo will cut all traction control systems off when engaged.
  10. Oct 16, 2019 at 4:56 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Said he was in 4hi. What gear was the truck in? 1000 rpm is just above idle speed. Depending on the gear and the incline you should have been 3000-5000 rpm's
    GreyBaldTaco likes this.
  11. Oct 16, 2019 at 5:56 AM
    GreyBaldTaco
    2019 F150 5.0
    The real hint is he was at ~1000 rpms with his foot to the floor. This makes me think traction control was doing its thing.
    Dryfly24 likes this.
  12. Oct 16, 2019 at 5:56 AM
    ryan760
    ryan760 Well-Known Member
    What he said ^
  13. Oct 16, 2019 at 6:01 AM
    Marshall R
    Marshall
    none
    Traction control applies brakes to spinning wheels. It does not change engine rpm. I'm thinking it was in the wrong gear. An automatic should have automatically downshifted. If it was a manual then operator error.
  14. Oct 16, 2019 at 6:05 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Can you describe the hill? How steep? Paved? Snow on the ground?
  15. Oct 16, 2019 at 6:07 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Not always. Mine has cut throttle when I stomped on it to keep wheels from spinning.
    Sterling_vH111 and GreyBaldTaco like this.
  16. Oct 16, 2019 at 6:08 AM
    ryan760
    I thought standard traction control did cut throttle, no?
    MTS and crawl control don't, but in 4HI, I believe it's just standard traction control.
  17. Oct 16, 2019 at 6:09 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I believe this is correct, most vehicles do this. I haven't lost traction in my Tacoma, so I haven't actually seen it first hand, on this truck anyway.
  18. Oct 16, 2019 at 6:36 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Traction control limiting throttle input and if low rpm in 1st then transmission isn't locked.
  19. Oct 16, 2019 at 6:46 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    If it’s a manual, they absolutely are that weak below 2k
  20. Oct 16, 2019 at 7:51 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    OP, include more detail?
    Mods?
    Transmission?
    CELs?
    Other lights?
    Offroad, on road?
    Junkhead likes this.
