Slow returning clutch pedal
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jester243, Jun 28, 2010.
  1. Jun 28, 2010 at 7:55 AM
    Jester243
    Jester243 [OP] rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    On my dad’s 2004 Tacoma he had been noticing his clutch pedal is slow to return, to the point that sometimes he has to pull it up with the toe of his shoe. He says the pedal seems to be low in the morning when he gets in the truck. I have checked and the fluid level is fine and there is no obvious signs of fluid loss that I can see. So any ideas?
  2. Jun 28, 2010 at 8:05 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
  3. Jun 28, 2010 at 8:16 AM
    Jester243
    Dan
    Spokane, WA
  4. Jun 28, 2010 at 8:17 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  5. Jun 28, 2010 at 8:34 AM
    Jester243
    Dan
    Spokane, WA
  6. Jun 28, 2010 at 8:36 AM
    Janster
    Jandy
    Lancaster, PA
    Look at it yourself....that's what the writeups are for.
  7. Jun 28, 2010 at 8:50 AM
    afd23a
    The Dynamo of Dixie
    does he still have any warranty on it with only 32k on it?
  8. Jun 28, 2010 at 8:52 AM
    Jester243
    Dan
    Spokane, WA
    No with it being a 2004 the warrenty ran out a couple of years ago.
  9. Jun 28, 2010 at 8:53 AM
    afd23a
    The Dynamo of Dixie
    I don't know how long most warranties last as I've never had one. I thought 36k but wasn't sure if there was a year limit as well.
  10. Jun 28, 2010 at 9:07 AM
    Jester243
    Dan
    Spokane, WA
    it's a 3 year/ 36,000 mile, what ever comes first.
  11. Jun 28, 2010 at 9:09 AM
    HomerTaco
    HomerTaco All up in your GRILL Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    HAd same issue with my 99' Taco - was a bad slave cylinder.:(
  12. Jun 28, 2010 at 9:35 PM
    offroadTRD
    offroadTRD Well-Known Member
    Dinwiddie County, Virginia
    2000 Tacoma V6 SR5 4x4 TRD- Fabtech
    Fabtech 3" adjustable coil-over system, Alcan 8-leaf spring pack, Fabtech 3" body lift.
    could be a slave, buy my issue was the master cylinder. when mine started doing it, I didn't worry about it for a while. Then at stoplights or intersections, etc., my clutch would engage itself while the pedal was pushed all the way to the floor. Got to be very very very dangerous. For a couple of days I before I got a change to fix it, I would just place the shifter in neutral and then place into first when i could. I replaced the whole clutch, flywheel, and pressure plate. after about two days, the clutch did it again. ended up replacing the master cylinder and it fixed the problem. just letting you know.
