Slow speed vibe... Maybe front brakes maybe not.
Discussion in 'Suspension' started by zgraphic, Jul 19, 2009.
  1. Jul 19, 2009 at 7:29 AM
    zgraphic
    zgraphic [OP] Member
    Sean
    Texas
    05 tacoma DC TX
    Under cover tonneau cover, 2006 OEM 16 inch Wheels, Yokohama geolander HTS tires, German shepherd mix guard dog
    Anyone had this vibration before?
    Hello all, new to the forum here.
    I am scratching my head over the Washboard like ride I get at very low speed (stopping and starting), 5-10 mph.
    Truck is at 60000 miles just did dif service, will be doing propeller shaft today. I did change the wheels from the stock 20 inch chrome godawfulness it came with to some nice unobtrusive Toyota Stock 16 inch rims from a 2006 Taco. At the same time changed tires to Yokohama hts geolanders.
    So far I have completed the following diagnostic work:
    Shudder occurs in drive and neutral brakes no brakes
    Removed rear drums and checked for warpage none found, replaced retension springs on both sides
    Had tire dealership install stock dunlops to rule out some of the posts I have read about Yokohama tires. And still had vibe
    That about covers it...
    Any advice would be appreciated. thanks and howdy,
  2. Jul 19, 2009 at 11:43 AM
    zgraphic
    Sean
    Texas
    05 tacoma DC TX
    OK so a quick Update and Another question.
    Took a look at the Carrier Bearing assymblw and it looks fine. But the more I think about the change in wheels the more I wonder about this as a culprit.
    Also took it up on the highway and have a noticeable hum between 55-65 mph.
    Can someone explain the geometry of the two different wheels. I think I have my head wrapped around it but would love some input...
  3. Jul 19, 2009 at 1:20 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Rotate the tires around - see if the vibration changes location/intensity.
    Wheels out of balance or warped/bent wheel?
    When did this vibration just occur? Did you install anything? Did you change anything? Did you perform any other maintenance just prior to the vibes occuring?
    Do you feel the vibration in the steering wheel?
  4. Jul 19, 2009 at 4:34 PM
    zgraphic
    Sean
    Texas
    05 tacoma DC TX
    Spent the day with the tire shop rotating the tires around and even changing out the new tires for stock dunlops with no change. Definitely not in the steering wheel.
    Others have suggested that it may be the carrier bearing.
  5. Jul 23, 2009 at 7:49 PM
    zgraphic
    Sean
    Texas
    05 tacoma DC TX
    Turns out it was Front U joint but there is also a TSB on the slow speed vibe/ TSB 0132-08. Transmission mount(s) should be covered under drivetrtain warranty.
  6. Jul 23, 2009 at 7:57 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    i have this same problem im taking my truck to the stalership tomorrow
