Slow speed vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmcnair327, Mar 7, 2012.
  1. Mar 7, 2012 at 5:21 PM
    jmcnair327
    jmcnair327 [OP] Active Member
    Baltimore
    05' Tacoma
    I have searched and have not been able to find another thread discussing a problem like this. I have a bad vibration from the front end when going under 5 mph. It gets a a little better if I engage 4wd but still pretty noticable. I have no vibration at all over 5mph. Does it while braking, coasting and under throttle. But only under 5 or 6 mph. All other vibration complaints I read about usually involve a high mph vibration, which over 5mph I am completely smooth. Stock 4x4 suspension, only larger duratracs (265-75-16). Seems way to bad to be from aggressive tread tires. Any thoughts??.....
  2. Mar 7, 2012 at 5:43 PM
    lonecountryboy
    lonecountryboy Well-Known Member
    Are you sure its from the front? Have you checked the drivers side CV shaft for the bearing being worn out? I had the same thing but it was the rear driveline causing it and it would vibe from start up to 5mph and right at 20-30mph drove me nuts. Also check the wheel bearings I see you have an 05 so the front wheel bearings would be a good start along with the CV shaft bearing. Just make sure everything is tight and lubed.
  3. Mar 8, 2012 at 7:57 AM
    jmcnair327
    Baltimore
    05' Tacoma
    Yes it is in the front. Was thinking a CV axle also. Do you mean the wheel bearing when you say CV bearing?
