Slow Start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dasp2121, Feb 7, 2024.
  1. Feb 7, 2024 at 10:21 AM
    dasp2121
    dasp2121 [OP] Member
    I have a 2013 Tacoma 4wd that was experiencing extremely slow cranking and start-up. On Thanksgiving day 2023, I replaced a dead battery. Once the slow cranking/starting began a few weeks after replacing the battery, I also replaced the starter with a rebuilt Denso. While the cranking is faster and it starts after a second, it is still slow to turn over compared to what it used to be.
    Another weird symptom is that the electric door locks have only half unlocked once or twice. You can hear a slow/weak unlocking/locking sound from the locks, and there have been a couple of times when the door will not unlock completely.
    I've also noticed the interior dome lights momentarily dimming when using the door locks too.
    I just bought a multimeter and my plan is to do some drop tests between the battery, starter, and alternator. But the dimming lights and intermittent issues with the locks are issues I haven't heard of before.
    I'm an electrical virgin and this will be the first time poking around the wiring, fuses, etc.
    Are there any ideas of where I should start my investigation? Has anyone had an issue like this before?
    Thank you for any help!
  2. Feb 7, 2024 at 10:25 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    You had the battery checked .....
  3. Feb 7, 2024 at 1:58 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Check battery voltage at the terminals first. That way you know what you're working with.
    You have to check voltage drop underload. So you'll need to be cranking the engine over to check it.
    As well as operating the locks and such.
    And easy(er) check would be right at the headlights.
    Terminal to cable clamp
    Terminal to Body
    Terminal to component......
    HondaGM likes this.
  4. Feb 7, 2024 at 3:41 PM
    dasp2121
    Alrighty...tested the battery at the terminals and I'm getting 10.72 volts. So, I'm taking it back tomorrow to see if they'll swap it out for me. Hopefully that will solve the issues.
    Steves104x4 likes this.
  5. Feb 7, 2024 at 3:59 PM
    TnShooter
    Deogee
    STOCK
    Maybe, But you could have a parasitic draw too.
    They are going to want to try to charge the battery and test it before swapping it out.
    You can't test a battery properly if it isn't 12.6v or more
    Might as well do them, and yourself, a favor.
    Charge it before taking it in to have it "swapped or tested".
    Or check for a draw on the truck first.
    Jimmyh and HondaGM like this.
  6. Feb 8, 2024 at 9:19 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Maybe the alternator is defective and not charging properly.
    Check voltage at the battery when the engine is running and see what it is. It should be over 13.5 VDC.
    TnShooter, wi_taco and HondaGM like this.
  7. Feb 8, 2024 at 11:23 AM
    Waasheem
    Waasheem
    2007 xrunner
    10.72 is with the engine running, not running, or while cranking the starter?
    Alternator is my first guess too but more information and probably further testing is needed.
    Op, provide us with 3 voltage readings. At the battery with the engine off 1, at the battery the lowest voltage reading while cranking 2, and at the battery with the engine running 3. 3 more would help too. The same previous situations but with the negative lead on battery negative, and the positive lead on the big starter terminal.
    Jimmyh[QUOTED] likes this.
  8. Feb 9, 2024 at 6:33 PM
    dasp2121
    10.72 was without the engine running.
    I took the battery back to Autozone yesterday. They tested and then replaced it. It has solved the issues, but I'm keeping an eye on it in case there is a parasitic draw or alternator issues.
    TnShooter and Jimmyh like this.
