Slow Starting... Any ideas?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nick_kellog9, Feb 2, 2023.
  1. Feb 2, 2023 at 12:56 PM
    Nick_kellog9
    Nick_kellog9 [OP] Well-Known Member
    Nicholas
    Eastern Shore MD / Daytona FL
    2002 Supercharged 5MT Lunar Mist
    OME's Firestone Destination AT/2 265/70r17 Nomad 501SA Convoy Salt Baja Designs Squadron Sport/S1 Leer Camper JBL/Pioneer Stereo
    Hey everyone, my 2002 is having a tough time starting. I thought it was a parasitic drain, which it could be, however it seems as though it is the starter going bad. At least that's what auto zone's test box thing said.
    This all being said, would a failing/failed starter cause any parasitic drain? ALSO, would it cause the engine to crank over at a VERY low speed when starting even when battery is charged?
    What would be the ideal fix here? I've read that aftermarket starters aren't very good, so looking at a reman perhaps, or a kit to do my own.
    Tips would be appreciated! Have an awesome weekend everyone!
    -Nick
  2. Feb 2, 2023 at 1:22 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It could cause a drain but it would drain the battery dead.
    Battery terminals and cables are tight and clean ?? Cables not corroded under the insulation?
    Pull the starter rebuild the solenoid .
    Buy a Reman Starter from Your Toyota dealer of choice.
  3. Feb 2, 2023 at 1:34 PM
    Nick_kellog9
    Nicholas
    I haven't looked at the cables, the battery seems to be draining at about .7V a day or so. Left it for 3 days and it went from 13 to 11.
  4. Feb 2, 2023 at 1:42 PM
    Bivouac
    How old is the battery ? Some as they age don`t hold a charge like when new.
    You can go through the fuse block testing circuits that should not be drawing any current.
    Using a test light .
  5. Feb 2, 2023 at 1:49 PM
    Nick_kellog9
    Nicholas
    It's a one year old Optima Yellow Top. Testes fuses with a multimeter. I feel like cables might be it. But starter is unknown age also
  6. Feb 2, 2023 at 1:53 PM
    Bivouac
    You can never go wrong rebuilding a starter solenoid .
    I have had upgrading the battery positive and negative cables cure parasite drains.
    I use 1/0 welding cable!
    Good Luck!
  7. Mar 21, 2024 at 2:46 PM
    Nick_kellog9
    Nicholas
    Update
    Replaced cables with ones from yotacables. Awesome kit. Also replaced starter and alternator. So far so good.
    TnShooter likes this.
