Slow starting sometimes just a click? (not dead batt)
Discussion in '1st Gen. Tacomas (1995-2004)' started by ubnpast, Feb 23, 2010.
  1. Feb 23, 2010 at 9:06 AM
    ubnpast
    ubnpast [OP] Well-Known Member
    Central Jersey
    Just picked up a 99 4 cyl reg cab 4x4 with 184k miles, original clutch (still good) & from the original owner. I thought it needed a new battery (even though old one was over 12.5 volts), went and got a brand new everstart maxx, chaged it a little and put it in, but still slowly starts as if the battery is dead, sometimes just makes one click.
    My guesses are: bad ground somewhere, or a bad starter or starter contacts, loose fuse? The Terminals are clean and tight.
    What do you guys think, I thought I would ask maybe its a common problem that I am unaware of.
  2. Feb 23, 2010 at 9:54 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    sounds like a bad starter
  3. Feb 23, 2010 at 10:04 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Check the connections on the solenoid on the starter as well as all other connections to/from starter/battery.
  4. Feb 23, 2010 at 10:07 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    x2
  5. Feb 23, 2010 at 10:08 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    X3
  6. Feb 23, 2010 at 10:11 AM
    98tacoma27
    Ben
    Not Beech Creek
    Bad contacts in the starter. A lot cheaper than buying a new starter.
  7. Feb 23, 2010 at 11:01 AM
    pdxwhiteout
    pdxwhiteout monster taco in the snow
    coty
    pdx
    monster tacoma
    3-inch body lift, 6-inch fabtech lift, 17-inch procomp black alloys wrapped in bfg 37s. trd v-6.
    one click would indicate a bad starter, several clicks would be a battery. try tapping on the starter lightly while trying to turn it over. this can free up a stuck solenoid and verifie a starter issue. also inspect your ground cable condtion to make sure its not all corroded, corrosion will cause a high draw and can act just like a stuck starter. good luck.
  8. Feb 28, 2010 at 10:29 AM
    ubnpast
    Central Jersey
    Sorry for the late reply. Got a new stater because I dont have time to deal with taking apart the old one, 2 days later I got rod knock and just sold it today.
  9. Feb 28, 2010 at 10:33 AM
    xSpyderguyx
    xSpyderguyx Well-Known Member
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    s40 Flowmaster 33" Toyo M/T tires 16" P.A wheels 3" revteck Suspension lift
    With older trucks (like my 2001) Id recomend re-wiring the engine block ground, and the chassis ground. And re-wiring the alternator wire that goes to your battery.
    i did it strictly for car-audio puproses, but it can greatly help the performance and life of your battery.
    I changed all the wires to 4guage. (The negative ground was literally 24 guage:()
  10. Feb 28, 2010 at 10:41 AM
    747 function > form
    1st Gen.
