Slowing down using tranny??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRD SPORT2016, Oct 27, 2018.
  1. Oct 27, 2018 at 5:07 PM
    TRD SPORT2016
    TRD SPORT2016 [OP] Well-Known Member
    2016 trd off road
    I slow down my 16' Tacoma usually by manually gearing down the tranny, saves a lot on brakes. By now you guys can tell I'm a rig driver. We use jakes all day long.
    Is there any negatives using gearing down tranny? Makes the rpm go up to 3500 every time I gear down.
  2. Oct 27, 2018 at 5:11 PM
    OmahaJeff
    OmahaJeff Well-Known Member
    Jeff
    I've heard it said that brakes are easier and cheaper to replace than transmissions or clutches.
    That said, if it's a manual, I do it all the time--always have. (My current car is a Miata, previous cars were WRX's, all with MT.) I have never had a problem with the transmission and have never had to replace a clutch with a probably a million MT miles.
    I'm sure someone with mechanic experience will contradict this, but that's my story.
  3. Oct 27, 2018 at 5:12 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I do it, especially when towing in the winter on icy/snowy roads and hills.
  4. Oct 27, 2018 at 5:13 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    Suppose you could say it's a little extra work on the synchros, but we all do it.
    It keeps you in the appropriate gear if you'd need to accelerate for whatever reason- accident avoidance, etc.
  5. Oct 27, 2018 at 5:15 PM
    gurneyeagle
    gurneyeagle Well-Known Member
    Saint Augustine, FL/Houston, TX
    2008 Tacoma SR5, 2018 Audi TT RS, 2018 Tacoma TRD Off Road (Cement), 2019 MDX
    Been doing it for years on track days and on the street.
  6. Oct 27, 2018 at 5:15 PM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Been driving toyota for 25 years only mt. It does not hurt them sure i go through a clutch in 100k but brakes about 150k. Only use brakes for an emwrgency. My 93 has 402k 3rd clutch n just did its 3rd brake job. Changing clutches ate easy. Dont let others fool you.
    gurneyeagle likes this.
  7. Oct 27, 2018 at 5:30 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    If MT, Keep up the good work. If AT, I'd let the pads and shoes do their sacrificial thing.
    JMO, YMMV.
  8. Oct 27, 2018 at 6:13 PM
    CleanWilly
    CleanWilly Well-Known Member
    2017 Access Cab Offroad
    Transmissions are not for slowing down on track.
    02Duck likes this.
  9. Oct 27, 2018 at 6:16 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    they are if youre slow :rimshot:
  10. Oct 27, 2018 at 6:19 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I've done it on every AT I've ever owned, especially coming down big hills. It doesn't hurt anything.
  11. Oct 27, 2018 at 6:24 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Safer on grades to let the tranny share the load but you already knew that. Only time I don't is when coasting up to a red.
  12. Oct 27, 2018 at 7:19 PM
    gurneyeagle
    They are as you are pulling off the track onto pit lane and into the paddock.
    I wouldn't quit my day job if I were you. :cheers:
  13. Oct 27, 2018 at 7:23 PM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    The brakes on this truck are pretty meh, or they are on the 2nd gens. Engine brake to your hearts delight. There's little if any fuel being delivered by the injectors if no throttle is applied anyway.
