Slowly grooming the old taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pikerup, Apr 25, 2011.
  1. Apr 25, 2011 at 6:03 PM
    Pikerup
    Pikerup [OP] Member
    IN
    1995 ext. cab 2.7 4x4
    Stock
    Not a mechanic, but I have managed to successfully replace all shocks and springs all around, RR'd the front 02 sensor(what a bitch-thank God for the Dremmel tool and an even hand on corroded nuts), the washer pump motor and the fan speed switch.
    Next up is all the 1995 factory belts.
    And....a question I'm hoping someone can enlighten me on...
    I plan on changing the distributor cap. No big deal.
    What about the rotor? Is that thing fixed in place only to be replaced with the distributor itself or is it easily replaced and I'm too big a wuss to give it a tug?
    I believe that this is the first of the first gens (1994.5). Any insight would be truly appreciated.
  2. Apr 25, 2011 at 6:08 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I was kinda nervous clicking on this title... If it was in the UG I definitely wouldn't have.
  3. Apr 25, 2011 at 6:12 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Not sure if the rotor is held in with a screw/bolt or not....
