sluggish accerleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coreyed88, Feb 27, 2013.
  1. Feb 27, 2013 at 9:18 PM
    coreyed88
    coreyed88 [OP] New Member
    '06 prerunner
    so on the way to work my truck performed normally. after work i was going 45mph and going up a slight hill and it started stuttering/skipping a little and was struggling to get up the hill so i accelerated and it dropped to a lower gear like it's supposed to, but just didn't have the power that it normally has. my fuel was low and i put some more in it and still the same thing...it's like it can't breath or it's struggling for gas. any suggestions?
  2. Feb 27, 2013 at 9:28 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    was the motor revving out still and just not going anywhere? or did it seem to be bogging and not accelerating?
  3. Feb 27, 2013 at 9:40 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Maybe it literally couldn't breathe. What's going on with the air filter? Fouled plug? Really could be a lot of things.
    Answer snowska8air2's question first, though.
  4. Feb 27, 2013 at 10:03 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Maybe op is a 4 banger? J/k
    How low of fuel? Really need more info, ( really steep hill? Maybe starved the fuel pump in the tank. )? I don't know, there are and could be lots of variables to your problem.
    Brett
  5. Feb 27, 2013 at 10:44 PM
    coreyed88
    '06 prerunner
    if i take it easy on the accelerator, it seems like everything's fine. it's just when i get down on it it's not as peppy and bogs down. however will eventually get up to speed. i'm waiting to check the air filter tomorrow when it's light outside, but i really don't think it's dirty because it was changed about 10,000 miles ago and i checked it two weeks back and it was clean.
  6. Feb 27, 2013 at 10:50 PM
    xyourlocaldjx
    xyourlocaldjx Well-Known Member
    clogged injector?
    no check engine light came on?
    When i accelerate hard I can hear a spraying noise from the engine. you hear anything different?
  7. Feb 27, 2013 at 11:18 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I'd clean the MAF sensor and look for vacuum leaks before changing out parts.
  8. Feb 28, 2013 at 5:26 AM
    nathan3306
    nathan3306 Well-Known Member
    Nathan
    Charleston AFB, SC
    2012 SR5 DC 4X4
    EDIT: Now that I think about it, you may want to try replacing the fuel filter first. It may have sucked up some of the trash at the bottom of the fuel tank with the low fuel level.
    How many miles are on the truck?
    Throttle body and mass airflow should be looked at/ cleaned. Diconnect the battery, maybe is will reset something in there.
    Replace air filter and fuel filter. You would be surprised how many people forget about the fuel filer and how dirty these things get.
    Spark plugs are good for ~30K miles.
    Fresh oil change and should be good to go.
    If it's still acting up.... I don't know what to tell ya.
    Good luck!
    Nate
  9. Feb 28, 2013 at 12:17 PM
    coreyed88
    '06 prerunner
    100k miles on truck. bought with 82k. air filter not really dirty...sucks plenty of air. it's almost as if the problem is gone now....hard to tell. if it is sluggish it's ever so slight, nothing like last night. could it be that i flushed something through by flooring it a few times last night because it's responsive now without any skipping or anything. blows.my.mind!!!
