Sluggish power steering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rat Man, Jul 13, 2020.
  1. Jul 13, 2020 at 10:01 AM
    Rat Man
    Rat Man [OP] Member
    My 2015 Taco seems to be pretty stiff in the steering. It doesn't help that I have injured both elbows and shoulders due to years at work.
    I'm wondering if there is a way to tune it up or replace the pump or box or some other part that will make cranking the wheel a little or a lot easier.
    Thanks,
    Ratman
  2. Jul 13, 2020 at 10:12 AM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    Have you checked the power steering fluid level?
  3. Jul 13, 2020 at 10:30 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Try this video....
    https://www.youtube.com/watch?v=bJnFJ0ZZwXQ
    To add; there are many ways to service the fluid in your power steering, this is only demonstrating one of them. Good Luck and let us know if this corrects your problem.
    Go Team TW !
  4. Jul 13, 2020 at 12:07 PM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    Check your lower steering shaft u joint. If you crawl under the truck, you'll see the lower steering shaft, and spray the lower u joint with Krown lubricant or similar. Made a world of difference on mine.
  5. Jul 13, 2020 at 3:57 PM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    If the power steering is getting stiff I'd first check the reservoir fluid. I'd also check out your intermediate steering shaft for rust and spray some penetrating oil on the u-joint area. Then I'd consider doing a complete flush of the power steering system (very easy, inexpensive and plenty of videos on how to).
    Last year I flushed my 2012 power steering system. Brown fluid out, fresh pink fluid in. And last month I replaced my intermediate steering shaft "due to power steering was stiff" plus shaft was rusted up pretty good. I'll now spray with penetrating oil spray every oil change since OEM Toyota shaft are not cheap!
