Sluggish takeoff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Knucklehead_Taco, May 17, 2024.
  1. May 17, 2024 at 12:23 PM
    Knucklehead_Taco
    Knucklehead_Taco [OP] You said cut the "BLUE" wire righ…
    California (Left Coast)
    2009 Tacoma 4x4 TRD Off-Road (4 door Crew Cab)
    4 inch lift - 20" Wheels M/T Tires - 4.0L VVTi V6 -
    Hey guys,
    I have an’09 Taco and have been fixing random bugs since I purchased it 3 years ago. No big deal, but the one I am having rough time with is every so often, usually when it’s warm, I have to mash the pedal to get it to pull out of it’s own tracks. I have been using an octane booster every few fill-ups and that seems to cure it for a while… I don’t have any knock sensor codes or throttle issues/codes to speak of… has anyone else had the same issues?
    PS… currently getting around 16mpg and I fill up using Chevron mostly/ using VP Madditive Octane booster-
    thanks in advance
  2. May 17, 2024 at 12:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Do you have any codes at all present?
  3. May 17, 2024 at 12:57 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Have you checked/cleaned the MAF sensor?
    Steves104x4 likes this.
  4. May 17, 2024 at 1:06 PM
    TnShooter
    Deogee
    STOCK
    I'm not saying the Octane booster isn't helping, but are you sure it is helping?
    The only thing octane booster will do is allow for more timing.
    If you have no codes, the only other thing you can do is look at live data.
    ZColorado likes this.
  5. May 17, 2024 at 1:07 PM
    saajanpatel1
    saajanpatel1 Well-Known Member
    Saaj
    MA
    2022 Tacoma Limited
    None
    Does it happen after it rains? Are you getting water in your intake from somewhere? Any way water getting into gas (but should resolve with the additives)? MAF Sensor cleaned? I am trying to think of all the reasons why warm weather would correlate to the problem you are facing.
    Do you have any leaks of any sort? Last time changed your spark plugs? Are the spark plugs on tight? Feeling any knocking (I know you don't have codes but if you feel a difference in the engine)?
  6. May 17, 2024 at 2:28 PM
    Knucklehead_Taco
    Zero codes
  7. May 17, 2024 at 2:28 PM
    Knucklehead_Taco
    MAF sensor is a few months old
  8. May 17, 2024 at 2:32 PM
    Knucklehead_Taco
    It will do it more if it is a hot day; if I am pulling a hill I will hear the engine pinging, which usually means garbage fuel… but it basically feels like I am towing a heavy trailer pulling away from a stop.
  9. May 17, 2024 at 2:41 PM
    Knucklehead_Taco
    I’m wondering if it could be the Cats?
  10. May 17, 2024 at 2:42 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Select low range on the gear lever and try it.
  11. May 17, 2024 at 2:44 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    How old are the sparkolators?
  12. May 17, 2024 at 2:51 PM
    Clearwater Bill
    Billy
    Largo Florida
    I've have detonation when running hot on a couple other marquees. Thought it was a few things but turned out to be inadequate air flow. Which in itself can be from several things
  13. May 17, 2024 at 2:59 PM
    Knucklehead_Taco
    I honestly can’t remember if I changed them or not… I changed to NGK coils, not sure about the plugs. I will check into it
    Steves104x4[QUOTED] likes this.
  14. May 17, 2024 at 3:00 PM
    Knucklehead_Taco
    Wondering if I should do a cold air intake
  15. May 17, 2024 at 3:00 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    If you can’t remember when… it’s probably time.
  16. May 17, 2024 at 3:10 PM
    Clearwater Bill
    Billy
    Largo Florida
    It has a factory one that's just fine.
    When I say airflow I'm talking cooling system, not intake.
    TnShooter likes this.
  17. May 17, 2024 at 9:50 PM
    Knucklehead_Taco
    Gotcha
  18. May 17, 2024 at 9:55 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Do you have a scanner that can graph data? If so I'd want to see what fuel trims and AFR/O2 sensors do when the problem is occuring.
    b_r_o likes this.
  19. May 17, 2024 at 10:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Fuel trims hold the answers
  20. May 18, 2024 at 9:32 PM
    Knucklehead_Taco
    I have a reader, but have only used it for simple codes. I will mess with it tomorrow and see what happens. It did start pinging again today so I bought some new NGK Laser Iridium plugs. I honestly think I might have blanked and never changed them when I replaced the coils.
    It’s been 3 years anyway so they are due to be replaced.
    I’ll keep you posted
