Sluggy uphill sometimes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Knucklehead_Taco, Aug 11, 2021.
  1. Aug 12, 2021 at 3:31 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Now that you have re-gapped the plugs and snugged them down properly, I recommend disconnecting the battery for a few hours to reset your ECU learning the proper firing and combustion in the engine.
  2. Aug 12, 2021 at 3:32 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Gapping iridium plugs :anonymous:
  3. Aug 12, 2021 at 3:36 PM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    How many miles are on the truck? Perhaps a transmission service is in order.
  4. Aug 12, 2021 at 3:39 PM
    Knucklehead_Taco
    Knucklehead_Taco [OP] You said cut the "BLUE" wire righ…
    California (Left Coast)
    2009 Tacoma 4x4 TRD Off-Road (4 door Crew Cab)
    4 inch lift - 20" Wheels M/T Tires - 4.0L VVTi V6 -
    I disconnected during the process... after cleaning up the mess, it had been around 2 hours-ish.
    JasonLee[QUOTED] likes this.
  5. Aug 12, 2021 at 3:42 PM
    Knucklehead_Taco
    151,xxx - I had a complete flush done at my local SpeeDee Lube... I just found that these have no filter... just a screen... weird.
    Maybe the shifting slow thing is just me not being used to this truck... I still may replace the sensors anyhoo...
  6. Aug 16, 2021 at 9:56 PM
    Knucklehead_Taco
    So... The Taco drives fantastic now... Ran it through my ODBII test and no trans or engine faults/codes... Now getting 26 mpg at my last 76 mile jaunt (as opposed to the previous 14.5 mpg) after gapping the plugs correctly...
    Now I just have to chase the shudder from the lift at takeoff.
    So far I've installed the Old Man Emu shims on the carrier housing. Not sure if its could be the carrier itself? I was able to move it quite a bit. How soft is that rubber supposed to be in the carrier housing?
    I also have a leaf spring shim kit I'll be installing this weekend or next.
  7. Sep 25, 2021 at 4:58 PM
    Knucklehead_Taco
    Anyhoo… after driving for a while I bought a brand new set of NGK Iridium plugs… gapped to .044 and took it for a test… needless to say I had a significant amount of power at takeoff.
    At the end of the drive the power loss came back. I ran an ODB and found that #1 had a misfire. Ordered a new set of NGK coils and they should be here by Oct 1st… tht seems to be the issue as when it’s cold it runs fantastic… after driving all day… the coils start losing their oomph… after 150,000 miles i gues its time to change them out
  8. Sep 26, 2021 at 5:50 AM
    Drtgrl
    Drtgrl Minus member
    Alana
    Foothills
    2015 MGM Tacoma DCLB
    BAMF sliders with kick up. BAMF all skids. Icons w/ CDC up front. Icon UCA's. All pro expos with 12” kings in rear. Wheelers superbumps. 285 stt pros on black 16" fj wheels. 1" Bora wheel spacers. Relentless tailgate reinforcement. Ditch lights front and rear. Aironboard switches. Aux. bussman box.Center console vault. Esp locking storage. Tuffy bed box. Rear seat molle system. Color matched grill.Rear diff breather mod. ABS switch. PrInSu cab rack. Gusseted spindles.
    That coil on number 1 sounds like your issue. Previous owner could have accidentally damaged it changing the spark plugs. Sounds like progress, hoping that’s your issue :fingerscrossed:
  9. Jan 6, 2022 at 7:43 PM
    Knucklehead_Taco
    Well, months later with no issues... Come to find out it was the fuel injectors. I took all of them out, cleaned them with injector spray while keeping the solenoid open with a 12v power supply that I rigged. This was coupled with the coils, I just bought all new NGK coils.
    3.5 months later, still no shudder, no loss of power and waaaaaaaaay better mpg... Running about 17-19 mpg up here in the hills.
    Woot
    Charlie Bravo and Drtgrl[QUOTED] like this.
  10. Jan 6, 2022 at 7:44 PM
    Knucklehead_Taco
    Update
    Woot
    EdableDonut and Aww Boo like this.
  11. Jan 6, 2022 at 9:09 PM
    EdableDonut
    EdableDonut Well-Known Member
    Raymond
    09 white Tacoma,
    None. 220k miles, just did a major brake/ suspension overhaul to keep him on the road.
    Hey good to know, my truck shudders going up a steep & windy hill. Thank you for doing most of the hard work, now I got a definitive place to start.
  12. Jan 7, 2022 at 10:40 AM
    Knucklehead_Taco
    I'll keep my fingers crossed for ya
