small back fire at start up!
Discussion in '4 Cylinder' started by Deer Slayer, Apr 15, 2009.
  1. Apr 15, 2009 at 10:57 AM
    Deer Slayer
    Deer Slayer [OP] Active Member
    NW Mississippi
    08 4X4 I4 MT Acc Cab
    I have noticed that some times when I start up my truck in the morning, specially if it is a little colder, that I hear what sounds like a mild back fire, or a sudden "puff" sound from the exhaust. I don't know why. I took it to the dearlership and left the truck there overnight so they could start it up first thing in the morning to hear it for themselves. They heard for themselves what I was talking about but they told me that there is nothing wrong with my truck, that they hooked up the diagnostics and everything checks good that it was "normal" and that it is doing that to warm up engine faster and bring it up to operating tempratures quicker!!!
    Have any of you experienced anything like this?
  2. Apr 16, 2009 at 10:52 AM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    I've heard what I think you're describing in mine too... and it's only a couple of weeks old. I think it's normal. It's nothing like a *POW* backfire. Not really a "pop" at all... more like "pfft"... sometimes a couple fairly close together. Only right after starting the engine when it's completely cold - like after it's sat overnight. Right? It's probably just the unburnt rich-mixture exhaust from the cold start lighting off in the cat or muffler. I think the purpose of the air pump in the emission system is to enable exactly that. Nothing to be concerned about. Now, if yours is worse than that - and it's something new that it's just recently started doing, then you mave have some kind of problem.
  3. Apr 17, 2009 at 11:07 AM
    Deer Slayer
    NW Mississippi
    that is a good discription of what I am experiencing. more of a "puff" sound than a loud "pow". I am glad to hear that is not any thing to worry about. I figured it would have something to do with maybe too rich a mixture at start up, probably commanded by the computer and temperture sensors to crank the truck faster on cold mornings (some thing to that effect).
  4. Apr 23, 2009 at 11:10 AM
    z33tec
    z33tec Well-Known Member
    Rochester, NY
    09 4X4 Access Cab 4cyl
  5. Apr 23, 2009 at 1:47 PM
    loggerpete
    loggerpete Member
    Mines a 95 and it does that too.
  6. Jun 3, 2009 at 6:05 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    My 09 backfires on startup. Sometimes small, other times it's a pretty loud pop / puff....
  7. Jun 3, 2009 at 6:37 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    The Batmobile used to do the same thing.
  8. Jun 3, 2009 at 7:06 PM
    Black08Taco
    Black08Taco Well-Known Member
    Baltimore,OH
    09 Super White Double Cab long bed
    Stock....For now
    Mine did that for a wile. I started to let it sit till it idled all the way down( about 20-30 seconds) before I shut it off and havent had that poof or back fire since then.
  9. Jun 4, 2009 at 4:21 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    My 09 does the same thing...
  10. Jul 18, 2009 at 4:35 PM
    Metal Magic
    Metal Magic Active Member
    Stockton Ca
    2007 tacoma access standad
    This is a release of cold pressure from compression. What you are hearing is the first strokes of the motor before shes making power. it should sound like air is blown out all at once in between the strokes. listen close, my 2007 does it every time I start it in the morning. nothing to worry about.
  11. Jul 19, 2009 at 11:10 AM
    arod
    arod Member
    tony
    bakersfield ca
    07 prerunner reg cab
    K&N intake, flowmaster 40 series
    I will admit that I like it when I start up in the morning and hear this with the flowmaster but that's just me as long as it runs strong and there is no check engine light lol
