Small dent, less than .5" in diameter
Discussion in 'Detailing' started by Nocturnal, Feb 24, 2013.
  1. Feb 24, 2013 at 1:18 PM
    Nocturnal
    Nocturnal [OP] Active Member
    Hawaii
    n/a
    I was taking my son out of the back seat (he sits in a car seat) and I ended up elbowing the back portion of my Tacoma, right between the back door and the rear window is at. Would paintless dent removal be a feasible option? Any ideas on how much it would cost? Also is it effective?
    It's probably the size of a nickel.
  2. Feb 25, 2013 at 5:06 PM
    bigweb2001
    bigweb2001 Active Member
    Atlanta
    TRD 4x4 Double Cab
  3. Feb 25, 2013 at 5:34 PM
    Scooter
    Scooter Canadian Member
    Manitoba, Canada
    08 Double Cab TRD Sport Short Box
    Pop n Lock Power Tailgate Lock, Bak Flip Tonneau Cover, Factory DLR installed, Defrost with A/C Off, EZ Down Tailgate Damper, Code Alarm Security System with Remote Starter, Rear Spring TSB, Ming rust proofing & paint treatment, 3M fabric protector, Cargo Mat, Scanguage II, DYI Illuminated 4X4 Switch, Versa-Gate box extender & cargo divider, Toyota Roof Rails, Grom USB Audio adapter with bluetooth, LED Bed lights, OEM Backup Camera with LCD Display Mirror
    I did the same thing with my elbow to the left side of the box. Paintless dent removal worked perfectly. It cost less than $100. However, since it was right above the fender flare, a few clips were broken when the flare was removed to fix the dent.
