Small Engine Has Me Stumped
Discussion in 'Garage / Workshop' started by knayrb, Jun 11, 2016.
  1. Jun 11, 2016 at 3:55 PM
    knayrb
    knayrb [OP] Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I have a Coleman 5000W generator with a Tecumseh HM100 10HP engine. I keep gas stored in the tank with Sta-Bil and carb cleaner. The gas was about a year old and is 10% ethanol. Each time I use it I turn off the fuel supply valve and let it stop on its own. It has always fired up on the 1st or 2nd pull and run for hours.
    Last week I fired it up and after 15 minutes it just sputtered a few times and stopped. It would not restart until it got cool. The length of time it runs is dependent on how warm the engine is. When warm and it finally does start, it might go 5 more minutes.
    Knowing that an engine needs 3 things, air, fuel & spark, Here is what I've done:
    Spark:
    This symptom has a bad coil written all over it. I've seen it many times. I replaced the coil and made sure the armature air gap is to spec at .125". Traded out spark plug with my mower of the same type. Nice and clean with gag set at .30" per specs. Mowed the lawn.
    Air:
    Filter is new. Tried with no filter.
    Fuel:
    Completely drained the older gas and blew out the tank completely dry. Ran carb cleaner through the hoses and replaced the fuel filter. Took off the carb and its as clean as a pin. Carb cleaner blasted through all orifices just fine. The carb is nice and shiny clean. I think the needle pin and seat are fine. I removed the reservoir nut and tank after mounting the carburetor. I opened the fuel valve and fuel tricked in. Lightly raising the float stopped fuel from entering the reservoir. Put in brand new 88 octane corn free fuel in the tank. No ethanol.
    Other:
    There is a low oil shutoff switch. Oil is to the top.
    With engine now cooler it started on 2nd pull and then again after about 10 minutes of running it just quit. What is the possibility of a DOA coil? I'm stumped. What should I try next?
    Thanks.
    Just thought of one: After it quits I'll pull the plug, ground it out, and see if there is a spark.
  2. Jun 11, 2016 at 3:59 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Maybe the gas is boiling in the carb, but I thought thatonly gave you trouble if you cut off a hot motor and tried to restart it hot. Just an idea
    Maybe the float sometimes is sticking
  3. Jun 11, 2016 at 4:11 PM
    GSHEP4
    GSHEP4 Well-Known Member
    Lehighton, PA
    2014 spruce mica sport
    s/c,fluid film, bug shield, window vents, under hood lights, bed lights, tailgate reinforcement, and more.
    Vaporlock?
  4. Jun 11, 2016 at 4:22 PM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    I know you said you cleaned fuel tank and line, but, I had similar thing happen to me. One time I had a small pebble stuck in the fuel line, it would allow enough fuel past to pool in the carb, but wasn't letting enough to keep running at full throttle. The other time was when my gas cap was not venting and carb would pull fuel until it was unable to break the vacuum, then starve for fuel.
    I know these aren't exactly the same as your situation, but I'd keep looking at fuel issues. Good luck, it sucks when your small motors have issues.
  5. Jun 11, 2016 at 6:46 PM
    knayrb
    Bryan
    Pure stock
    Thanks guys.
    It does act like it's starving for fuel just before it quits. You can see the hose inlet down right in the center of the gas cap. I'm going to replace the fuel line since I have some fuel hose laying around. I'll see if there light through the outlet. The cap does breath fine. If the spark turns out good after a shutoff, I might try a carb rebuild kit or a completely new for $79. The generator is worth it and works great when running. Also I feel better having a source of power to run my fridge, freezer, circulation fan on my fireplace, and furnace if there is a natural disaster or long term power outage.
  6. Jun 12, 2016 at 2:24 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Cooling issues caused by a mouse nest? Had that happen on a mower with similar symptoms.
  7. Jun 12, 2016 at 2:44 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    Not sure how old the motor is or if it applies to the 10hp motors but on the newer small hp motors they replaced the the adjustment screw on the bottom of the carb with a screw/bolt that has a small pin hole in it. This is the bolt that hold fuel bowl on.
    To fix shut gas off or clamp gas line take bolt out and blow out the pin hole with a compressor or similar.
    Could be an easy fix, this pin hole gets clogged up on all my small engines just about every year.
  8. Jun 14, 2016 at 7:16 PM
    knayrb
    Bryan
    Pure stock
    SOLVED: So an easy try was disconnecting the low oil shutoff switch from the coil. Bingo, it ran for over an hour in 85 degree heat. Doesn't even have the occasional misfire like it did before. Problem solved. A new switch is $46. I'll check the oil every few hours on my own for that price.
    I was going to buy the poster with the correct solution a full year's worth of gas but no one got it right. Sucks to be you. :rimshot: (No changes to your post. I have a screenshot saved as proof.) I will offer a heartfelt "thanks" to those that gave suggestions though.
    Nickel likes this.
  9. Jun 14, 2016 at 8:45 PM
    Nickel
    Diego
    2013 T/X TRD
    Just glad you figured it out! I could have used a years worth of gas though...:thumbsup:
