Small leak, please help me identify
Discussion in 'Technical Chat' started by nammer, Jan 29, 2013.
  1. Jan 29, 2013 at 5:42 PM
    nammer
    nammer [OP] Well-Known Member
    Nam
    Bradenton, Florida
    2006 DCSB
    Relentless Aluminum Front Bumper Maxtrac Spindle Lift and 3'' Spacer Allpro Standard leaf and 2'' block
    Hi, I was wondering if someone could tell me what is causing this leak, and what type of fluid it is? atf? oil? it's actually worse than it looks, i touched a drop of it, so you can't really see it pooling anymore
    thanks
  2. Jan 29, 2013 at 5:46 PM
    goufcustom
    goufcustom 7.62x63mm
    MD
    2006 4x4 TRD Off Road DC SR5
    Bed Topper, Diff Breather, aFe Cold Air Intake, Satoshi Grill, Moved Horns, Oil Catch Can, Tailgate Lock, Husky Mud Flaps, H4 65/70W Bulbs, Lower Grill Mesh, TRD Skid Plate, LEDs in the bed, LEDs behind the grill for accent lighting, Parking lights as turn signals, LED turn signals and reverse lights, 5100s up front, eibachs up front, SS extended brake lines all around, 1.5" AAL in the rear, Relentless Fab U-Bolt Flip Kit, ICON Progressive AAL, TRD Wheel Center Caps, HomeLink, Heated Driver Seat, Hella 500 FF Driving Lights, BAMF Diff Skid, BAMF LCA Skids, BAMF Rock Sliders w/ KickOut.
    Assuming you have a PreRunner, and that is the transmission. Are you refering to the dark, almost black stuff near the snap ring on the U-Joint?
  3. Jan 29, 2013 at 5:48 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    Don't see a leak. Can you specify where you believe it to be? If you are referring to the grease slung from the u- joint, that is normal. Don't forget to grease the u- joints about every other oil change or sooner.
  4. Jan 29, 2013 at 5:54 PM
    nammer
    Nam
    Bradenton, Florida
    2006 DCSB
    thanks for the quick replies guys, yea it's a prerunner, there is a small pool of something here, it seems like oil to me, yea it doesn't seem like much in the picture, but i just wiped it with my finger, so the drop is gone
  5. Jan 29, 2013 at 5:56 PM
    goufcustom
    MD
    The boxed location would be transmission fluid. I have no idea why there would be fluid there, hopefully someone else will chime in with an answer.
  6. Jan 29, 2013 at 5:56 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    stupid seal BS..............toyota upgraded it a few yrs ago....
  7. Jan 29, 2013 at 5:57 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    That is a very minimal amount. If it is not leaving a spot where you park every day, I wouldn't be overly concerned.
  8. Jan 29, 2013 at 6:02 PM
    nammer
    Nam
    Bradenton, Florida
    2006 DCSB
    yea it's the first time i noticed it, i gotta keep a better eye on it, i know my sisters car is leaking in the driveway, i always check near the oil pan, so this could be contributing to the mess
  9. Jan 29, 2013 at 6:18 PM
    nammer
    Nam
    Bradenton, Florida
    2006 DCSB
    i'm prob a retard, it could just be grease and dirt, and I just washed the car, so maybe the dirt/grease got wet, I'm gonna drive it around and keep an eye on it, here's a better pic of it, and I just wiped it off
    thanks a lot guys!
  10. Jan 31, 2013 at 4:16 PM
    nammer
    Nam
    Bradenton, Florida
    2006 DCSB
    just wanted to update u guys, doesn't look like any of the wetness has come back, so it prob wasn't even leaking, thanks for all your help guys, TW is awesome
