Small lift good ride
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mickdizzle, Jan 9, 2012.
  1. Jan 9, 2012 at 7:05 AM
    Mickdizzle
    Mickdizzle [OP] Well-Known Member
    Montana
    12 TX Pro
    I have been researching a small lift and I want a few things out of my lift. I use my truck for some off road use but I also do a lot of highway driving and some towing of a jumping jack with 2 four wheelers on it. I want something that is not going to bottom out when I am towing, something to support a front plate bumper in the future, and something that is going to ride as close to stock as possible.
    Here is what I think i am going to go with...
    Front-OME 886 Coils w/ OME Nitrocharger 90000 shocks
    Rear-Toytec 2" AAL w/OME N182 Shocks
    Is there something better out there for the price. I am looking at $779 for the parts and $370 for install and alignment. Is that Toytec AAL a good one or would I be better off going with the ICON?
  2. Jan 9, 2012 at 9:06 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    The set up for the front is ideal for a heavier set up, like an ARB style of bumper with a winch. Its actually designed for that set up they say. But if you run this set up until you get your bumper and winch, it will be a stiff, no where close to a stock ride until you do... and if you just do a lighter style plate bumper without a winch, you may want to go down to the 885's?
    Not sure how much weight your towing, so I really can not comment of the rear set up, but this will work fine with this lift.
    The icons CO's will work great, give a good ride but you will pay a lot more for them. Probably overkill for most people, but a great option if you do not mind spending the cash. Good luck
  3. Jan 9, 2012 at 9:09 AM
    Mickdizzle
    Montana
    12 TX Pro
    I am looking at the ARB or the Demello plate bumper. Do you know the weight of the demello? I want a good ride but you are right the icons are double the price of the toytec
  4. Jan 9, 2012 at 9:11 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    I believe the demello weighs in a bit over 100lbs.
  5. Jan 9, 2012 at 9:19 AM
    Mickdizzle
    Montana
    12 TX Pro
    That is lighter than the ARB. Would the 885's suit that bumper ok?
  6. Jan 9, 2012 at 9:21 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    OP , are you going to run a winch ?
  7. Jan 9, 2012 at 9:22 AM
    Mickdizzle
    Montana
    12 TX Pro
    Yes I am going to go with a warn or smittybuilt
  8. Jan 9, 2012 at 11:28 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Then the 885s should be fine. A local member here had a Relentless bumper with winch, Relentless sliders, and Bud Built skids on his AC and put 886s on it but it was way too stiff so he went back to 885s with a spacer.
  9. Jan 9, 2012 at 12:14 PM
    Mickdizzle
    Montana
    12 TX Pro
    alright thank you for the help. How much does the 885's raise the front end? damn there is so much contradicting info on these forums. Everytime i think i got it figured out i end up finding something else out
  10. Jan 9, 2012 at 1:25 PM
    4Wheelin4Banger
    Randy
    On my 4Banger AC 3", on OZ-T's V6 DCLB 2 1/2". Both without spacers.
    My guess on a V6 AC 2 3/4" without spacers and maybe around the same with spacers after you install bumper & winch.
  11. Jan 10, 2012 at 11:37 PM
    AWalker
    AWalker Well-Known Member
    Adam
    Tacoma Washington
    08 DC LB SR5
    O.M.E 885 Dakars nitros Snugtop allpro skids allpro bumper 4X inovations sliders Jayco pop up camper Torklift tiedowns
    I cant coment on the 885's w a winch and bumper but w/o them on a double cab they ride great. As for the rear I would spend a little extra and get the dakar springs from o.m.e. and put them in yourself. The fronts a chalange but the rear is simple w basic tools. I tow a trailer loaded w concrete, aprox 4k combo and tows way better than stock. Also have a 1200lb camper and hasnt bottomed out since.
  12. Jan 10, 2012 at 11:40 PM
    OZ-T
    Peter North
    British Columbia
    Welcome
  13. Jan 11, 2012 at 11:35 AM
    Syncros
    Syncros Well-Known Member
    How do the Dakars ride? my TSB's are just dickered at 190,000km, I mean, they still work fine, aren't sagged, and carry a decent load but they are S shaped from axle wrap. Looking at a full OME set up for my Access cab.
  14. Jan 11, 2012 at 11:44 AM
    OZ-T
    Peter North
    British Columbia
    Stiffer than the 4 leaf pack , but not harsh . Great load carrying ability and decent flex .
  15. Jan 11, 2012 at 12:09 PM
    Syncros
    Good to know. I could always pull a leaf if its too much I suppose. That said its a truck, im used to the harsh ride in my 82 and I haul lots of weight from time to time.
  16. Jan 11, 2012 at 12:10 PM
    OZ-T
    Peter North
    British Columbia
    If you haul you will be happy with them . I'm actually going to add the OME AAL to my pack .
  17. Jan 11, 2012 at 12:14 PM
    Syncros
    Right on. My bed mat weighs over 100lbs alone so I think I will be fine.
  18. Jan 11, 2012 at 12:16 PM
    OZ-T
    Peter North
    British Columbia
    Which mat ?
  19. Jan 11, 2012 at 12:21 PM
    Syncros
    Its just some big old industrial mat I found, its a good 3/4" thick and steel belted, cut it to fit.
  20. Jan 11, 2012 at 12:23 PM
    AWalker
    Adam
    Tacoma Washington
    08 DC LB SR5
    About 12k on mine and no noticeable sag so far and i way overload my truck on occasion. Ride well unloaded too. The only thing I dont love about my O.M.E. set up is the rake is alittle steep. Evetualy il put some spacers up front but realy dont want to wrestle those springs again. I put add a leafs in my cheokee and they didnt last long so didn't want to go that rout again w my Tacoma.
