Small lift on SR5 - Have I missed anything?
Discussion in 'Suspension' started by Ronn, Jan 1, 2013.
  1. Jan 1, 2013 at 10:04 AM
    Ronn
    Ronn [OP] Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    I have a 2007 SR5 4x4 with the 4 leaf rear, running stock SR5 rims with Hankook Dynapro 265/75/16. I'd like to do a small lift because my front springs seem to be sagging a bit. 2 inches would be perfect and don't like the idea of blocks etc.
    On my list so far:
    Bilstein 5100 adjust. front shocks
    Front shock bushing washer kit
    884 coils
    1/4 inch top plate spacer
    1.5 inch AAL from toytec
    I had my shocks replaced under warranty at around 160k, I now have 195k. Are the rear shocks good enough to accomodate a small lift? Or will I have to get new rears aswell.
    The only off roading we do is to get to our fishing spots or to go hunting, nothing crazy.
    Suggestions welcome.
  2. Jan 1, 2013 at 10:06 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The OME trim packer only works with OME shocks
  3. Jan 1, 2013 at 10:12 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Since you want just a small lift you could save money and just adjust your 5100's with the stock springs instead of getting the 884's. If you dont go with bigger tires you shouldnt need new UCA's. You should also be able to get away with your stock brake lines.
  4. Jan 1, 2013 at 10:13 AM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    That trim packer is to correct the lean right? So if I'm using the bilsteins will it have the lean or will I just have to deal with it?
  5. Jan 1, 2013 at 10:15 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    It will still have the lean but I dont see why you couldnt use the trimmer pack with the 5100's? I could be wrong though. :cool:
  6. Jan 1, 2013 at 10:20 AM
    OZ-T
    Peter North
    British Columbia
    OP , add a 1/4" top plate spacer to the driver's side
  7. Jan 1, 2013 at 10:20 AM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    That is a good idea, I've read that setting the bilsteins at 2.5 would produce a harsh ride and I was worried with them set at 1.75 it would still have a huge rake. I don't mind if the truck has a little rake, I'd prefer that over the front looking higher than the rear.
  8. Jan 1, 2013 at 10:23 AM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    This is what I've gone back and forth with as well. Shocks plus springs seem to give you a better ride, yes? Since you aren't pre-compressing the shocks?
    To the OP - I've gone back and forth quite a bit with a similar setup plan. I've settled on the same setup as yours except with the Wheeler's progressive 3-leaf pack as the AAL. OME springs and Bilsteins set to zero seem to be a good combo.
    Then again, if you're setting them to zero, maybe there's a non-adjustable set that's cheaper and equal or better quality? Dunno...
  9. Jan 1, 2013 at 10:27 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh thats right I forgot about the top plate spacer....good looking out.
    I have 885's with the top plate spacers and 5100's set at 0" and the ride is a little stiff but nothing terrible.
  10. Jan 1, 2013 at 10:36 AM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Ok will get the top plate spacer for the drivers side. What about the rear shocks? I currently have the yellow and blue bilsteins. Will those handle the 1.5 inch AAL? Any recommendations?
    And the tires I have now are obviously wider than stock. They balloon out to the sides a little. I'd like to keep the stock rims for now if possible. Have any of you had trouble with them rubbing the uca's while turning?
  11. Jan 1, 2013 at 10:41 AM
    Polymerhead
    Missouri
    I have the same wheels and tires exactly, and I get rubbing very infrequently at full lock turning into a steep hill, but that's it. You're already running those tires and wheels - I don't think you'll have any more rubbing than you already have.
  12. Jan 1, 2013 at 10:54 AM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    I was just thinking by lifting you change the angle of the control arms, so if the truck moves up, the uca may be closer slightly to the tire.
    I do get rubbing sometimes like you mentioned. Noticed it started to happen over the past year but never before when the truck was newer(I've always run that size of tire) That's what makes me think the springs are slightly worn out and maybe sagging a little.
  13. Jan 1, 2013 at 6:22 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Polymerhead, what shocks are you running on the rear?
  14. Jan 1, 2013 at 6:40 PM
    Polymerhead
    Missouri
    Stock - I'm all stock suspension-wise. Sorry if I confused anyone, I haven't actually bought a lift, but I have read about every thread about them. OME plus 5100s all around plus a wheelers progressive leaf pack are going on my rig at first sign of sagging. Only 25k miles on her right now though, so she's good to go for now.
  15. Jan 1, 2013 at 7:13 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Oh ok. Only thing is toytec lists the rear bilsteins good for 0-2" lift but on other sites they say the rear bilstein is only good for 0-1" lift. Does anyone know which it is? I'm planning a 1.5" AAL and wouldn't want to over extend the shock.
  16. Jan 2, 2013 at 7:48 AM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    I also noticed above the front springs there is a rubber bushing in between the spring and the mounting plate on the truck. Doesn't look like the strut bushing kit from toytec comes with this bushing. Where are you guys getting that part? I'd like to to replace everything there while I'm in there.
    Bump for some info about the rear shocks too... going to get some install quotes today.
