Small lift option for 2nd Gen
Discussion in 'Suspension' started by JBlood9, Nov 22, 2011.
  1. Nov 22, 2011 at 12:42 PM
    JBlood9
    JBlood9 [OP] Well-Known Member
    Jordan
    Baton Rouge
    Black 08 SR5 PreRunner
    Pesonal LSU plate. Flowmaster 40 Series BFG A/T KOs on TRD rims AFE Cold Air Intake (Pro Dry S) Weather Tech Digi Fits Sportsman Camo Shadowgrass custom seat covers. Custom Trailer Hitch receiver flag pole. Front and back matched tint. AVS rain guards. Pioneer CDE 123 head-unit. Derped Rims and Rear Bumper. Yellow Badges.
    I've been bouncing back and fourth for months now trying to decide what lift I want to do and how I'm going to do it.
    I know the option of 5100s and an AAL (hopefully i can just get the TSB) is popular.
    With the horror stories of spacer lifts, I dont want to go there and take a chance either. Not with my luck.
    I've also been given the suggestion of coils and a plate to lift it up some.
    My whole thing is this: Ideally, I would like 3inches. But, I can not afford UCAs (if you go with the "cheaper" routes) or the price of a big true suspension lift. I know going 5100s and aal or coils etc will not get me 3in but im good with that. Basically the closer to 3 the better. TIA.
  2. Nov 22, 2011 at 12:46 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What's your budget and what do you do with the truck? Is the lift for looks or will you be off roading?
  3. Nov 22, 2011 at 12:54 PM
    JBlood9
    Jordan
    Baton Rouge
    I have about $400 for parts. A buddy of mine can do the install in a breeze for free. And its semi for both. I only have 2wd which is why i'm not worried about getting my full 3 or more, but i do a ton of hunting and "use" my truck a lot. She's even been in the mud probably 5 or 6 times in the 7 months I've had her.
  4. Nov 22, 2011 at 12:59 PM
    Pugga
    Massachusetts
    $400 in parts your best bet would be 5100's up front set at 1.75 and a TSB rear with 5100's back there as well. If you want to go higher, you could go to 2.5 up front on the 5100's but then you have to make some decisions as to which AAL and shocks for the rear since you wouldn't be able to get 5100's and an AAL while staying under $400.
  5. Nov 22, 2011 at 1:07 PM
    JBlood9
    Jordan
    Baton Rouge
    thats what i figured would be happening. If all i do is TSB in the rear, it would be optional 5100s in the back right?
  6. Nov 22, 2011 at 1:17 PM
    Pugga
    Massachusetts
    Correct, 5100's would be optional in the rear with just the TSB leaf pack. The 5100's will ride better but stock Bilsteins will do fine.
  7. Nov 22, 2011 at 1:24 PM
    JBlood9
    Jordan
    Baton Rouge
    i'll sacrifice some ride to same the bucks. Just if/when i decide to go up with the rear i'll get the 5100s and bigger AAL and just adjust the front to 2.5....
    Anyway, doing this shouldnt give me any UCA problems or anything stupid right?
  8. Nov 22, 2011 at 1:25 PM
    Pugga
    Massachusetts
    At 1.75, you should not have any issues with your UCA's, at 2.5 it's a coin flip although several members are at 2.5 with stock UCA's.
  9. Nov 22, 2011 at 1:45 PM
    JBlood9
    Jordan
    Baton Rouge
    Just what I thought, and the luck i was talking about. But, sounds good. What vendors have the best price for some 5100s? or any of them offer a TW discount?
  10. Nov 22, 2011 at 1:48 PM
    Pugga
    Massachusetts
  11. Nov 22, 2011 at 2:07 PM
    JBlood9
    Jordan
    Baton Rouge
    thanks for the info/input man! appreciate it
  12. Nov 22, 2011 at 2:25 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    If you were to raise your budget a little you could do 5100s at 0 with eibach coils which yeild 1.6" of lift. Actually front 5100s would be 180 and coils are 150 so for 330 you have parts and getting the tsb will have you set!
  13. Nov 22, 2011 at 3:12 PM
    JBlood9
    Jordan
    Baton Rouge
    what would be the purpose of that if just straight 5100s gives me 1.75?
    Couldnt you run the 5100s at .85 and tack the coils on though for more lift?
  14. Nov 22, 2011 at 7:12 PM
    NC15TRD
    Nick
    PA
    The purpose of that is to get the lift by letting the coils do the lifting and not the shocks. You can set the 5100s at .85 and run eibach coils and is actually the setup I run.
  15. Nov 22, 2011 at 7:33 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    The main drawback to the "Bilstein Lift" is that you are compressing (pre-loading) the spring before it even goes to work. You get lift at the cost of ride quality.
    If you're lifting with the spring in its normal state (some OME, Eibach lifts) the spring is functioning within its normal design parameters. You get lift via overall spring length. You would also get a little more travel.
    So it's pre-load vs. no (or minimal) preload.
  16. Nov 22, 2011 at 7:42 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    How exactly do you get more travel with an OME lift over a bilstein 5100 lift?
  17. Nov 22, 2011 at 7:47 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    Ive got 5100's in the front at 2.5" with stock uca's and havent had any problems. And it looks a hell of a lot better! I just hate the stock tires with the lift now. Time to invest in tires
  18. Nov 22, 2011 at 9:12 PM
    jflan
    Vancouver, WA
    Well, you have the top hat and the seat.
    The spring is contained in that zone. As soon as you start adjusting the Billstein seat upwards, you are making that space smaller and the room to travel less.
    Seems like they don't encourage the 2.5 setting and hopefully it doesn't allow stacking if it is used.
    It's a good, economical lift and many like it.
  19. Nov 22, 2011 at 9:19 PM
    facebreaker1212
    facebreaker1212 Member
    Buffalo, NY
    06 TRD SR5
    I have 5100s in the front topped out at 2.5", Skyjacker AAL in the rear for 2". I am very happy with the ride and the look. I got my shocks from Wheeler's and the AAL from a local shop Jim Dean's Off Road.
  20. Nov 23, 2011 at 3:38 AM
    NC15TRD
    Nick
    PA
    You would regain the uptravel lost by not preloading the spring
