Small Lift Options??
Discussion in 'Suspension' started by dza1284, Mar 16, 2011.
  1. Mar 16, 2011 at 9:37 AM
    dza1284
    dza1284 [OP] Well-Known Member
    CA
    08 OR Short Bed Dbl Cab
    Bilstein 5100, 2" AAL, Grille, BHLM, Footwell LED, Dash LED, Aero exhaust
    I would like to lift my 2008 4x4 Tacoma 2-3". At first I was just going to put a 2.5" leveling kit on the front until I came across add a leaf. What would people who have done this before reccommend? Just leveling kit? Leveling kit and add a leaf?
    If option two, is the following link a good deal/quality product?
    http://store.fatbobsgarage.com/_toy...add-a-leafs-4wd2wd-2005-2011-6-lug-p2147.aspx
    Also, is this something that I can do myself without a lot of experience in auto work?
  2. Mar 16, 2011 at 9:46 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Stay.... Away... from.... leveling kits... You will hate it as soon as it's installed and on the road, the ride will go to shit. Get 5100s adjust them to 2.5" with an AAL from downsouthmotorsports.com
    What do plan on running Tire/Wheel?
  3. Mar 16, 2011 at 9:55 AM
    dza1284
    CA
    Honestly, I am really just focusing on the lift at the moment. I know it will probably look awkard for a bit but I have about 31k miles and want to wait until my tires need replacing before buying new ones.
  4. Mar 16, 2011 at 9:56 AM
    dza1284
    CA
    Are the leveling kits really that bad? I really just want to get a few inches of left without drastically altering the vehicle or spending too much money.
  5. Mar 16, 2011 at 9:59 AM
    CrazyCooter
    CrazyCooter Hold My Beer!
    Johnathan
    Germany
    2006 DCSB TRD Sport 4x4
    De badged tailgate,LED dome light,removed mud flaps,tail gate anti-theft mod,Maglite seat mount,rear diff breather,blacked out Tacoma emblems, blacked out Toyota emblem,foglight anytime,plastidiped stock rims,BHLM, behind grill light bar w/2 Hella 500FF lights, shortened 18" stock antenna, weathertec floor liners, Hi-lift, 3'' Toytec Ultimate with AAL, AVS Rainguards, Wet Okole seat covers, lowprofile tool box, pro comp 7089 w/33'' KM2s, flowmaster 40 series muffler, hidden CB mod w/firestick antenna.
    my leveling kit wasnt bad at all actually i got the readylift lift and level kit. I like it but over all i think i would have done a toytec lift if i had to do it all over again
  6. Mar 16, 2011 at 10:02 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Just get the 5100's and you can set them to level the truck you will be much happier and it's not that much more money and the install will be the same process and the leveling kit (removing the shock, compressing the spring, braking down the shock and putting it all back together)
  7. Mar 16, 2011 at 10:53 AM
    dza1284
    CA
    What toytec lift are you speaking of? The spacer and add a leaf (seems like it should be pretty much the same product no matter where you get it from) or a shock?
  8. Mar 16, 2011 at 12:10 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It depends on HOW or WHAT they use ...... in paticular, you want to avoid TOP PLATE SPACERS.
    Just do some research on this forum. 2-3" lift is standard for most folks on this forum. In fact, 2-3" is the most you can get out of IFS (without changing the current suspension configuration).
    There are 3 ways you can lift your vehicle:
    FRONT:
    Stock shocks + new coil springs
    Stock shocks + stock coils + coil spacer (internal)
    Adjustable front shock + stock coil springs
    REAR:
    Add-a-leaf to your original leaf pak
    New leaf pak
    Lift Blocks (I wouldn't recommend)
  9. Mar 16, 2011 at 12:14 PM
    802YOTA
    802YOTA Well-Known Member
    Scotty
    Vermont
    03 Tacoma SR5 TRD
    LEAF SPRUNG SAS, 5" inch springs 5" shackles. Tacoma HIGH STEER, CHERRY BOMB 3" Straight pipe, TRIPLE CASES, 5.29s, (yeah she crawls) LOCKED FRONT AND REAR, Custom square stock front driveshaft 13" slip(been there for a year and hasnt failed yet.), Ruff Stuff 8 inch Perches, 2" RB body lift, K&N intake, Zoom high performance Kevlar clutch, herculined flares and rockers, trail gear rock sliders, rock lights.
  10. Mar 16, 2011 at 12:33 PM
    dza1284
    CA
    Well I think I am going to add a leaf to the rear. The question which of those three options to do to the front. I was orginally just going to go with a spacer which some people dont mind, but then you go the suspension enthusiasts who say its terrrible and you have to buy a $2000 suspension.
    So I am basically looking at:
    1) Front Spacer, Rear add a leaf
    $169.99
    or
    $229.99
    http://www.toyteclifts.com/index.ph...tegory_id=113&option=com_virtuemart&Itemid=72
    (toytec was recommended, not sure if the brand matters when purchasing a leaf and spacer)
    2)Front Bilstein Shock, Rear add a leaf
    $225-$280 depending on the leaf
    http://downsouthmotorsports.com/i-1...pre-runner-4wd-front-pre-load-adjustable.html
    Leafs(not sure of the difference between the leafs):
    http://store.fatbobsgarage.com/toyota-tacoma-long-add-a-leaf-spring-lift-kit-1995-2009-p2126.aspx
    http://store.fatbobsgarage.com/toyota-add-a-leaf-spring-lift-kit-1963-2010-p2096.aspx
    http://store.fatbobsgarage.com/_toy...wrear-tsb-springs-2wd4wd-1995-2011-p8024.aspx
    3)Front Coils, Rear add a leaf
    $299
    So I am looking for recommendations from someone who is not biased towards buying the expensive suspension.
  11. Mar 16, 2011 at 12:43 PM
    dza1284
    CA
    Also I was just reading if you add a leaf then "Because you’re changing the stiffness of the spring, new shocks are recommended."
    Is that needed?
  12. Mar 16, 2011 at 1:13 PM
    802YOTA
    Scotty
    Vermont
    03 Tacoma SR5 TRD
    new shocks in the back would be needed i do believe.
  13. Mar 16, 2011 at 1:28 PM
    JLee
    Jerry
    Bay Area NorCal
    you don't need to buy a $2000 suspension my first setup was around 750 here is a link to the thread i posted when I bought it. now it will be a little more for a 2nd Gen but well under $1000 http://www.tacomaworld.com/forum/1st-gen-tacomas/112771-just-bought-my-lift.html
  14. Mar 16, 2011 at 1:35 PM
    Janster
    Jandy
    Lancaster, PA
    They recommend them, but new shocks are not needed. You can get shocks later.....
    The only real concern about shocks, is the length. Once you lift the truck - it will extend your shocks further than previously. You wanna make sure you're not over extending them.
  15. Mar 16, 2011 at 1:41 PM
    K3KamilK3
    K3KamilK3 Well-Known Member
    Kamil
    Wilmington, De
    08 PreRunner SR5 TRD Off-Road DC SB
    Blisteins 5100's all way around, 2'' AAL, LR UCAs
    I went with 5100s all the way around. Front set at 2.5 leveled out the back with a 2" Toyo Tec AAL. I got the 5100s from downsports for like 283 with the tacomaworld discount. Then the AAL was about 100 shipped from toyotec. That will give you a small lift for under 400 if you do it yourself. I took the advantage of the group buy and bought the LR UCA s. You don't need them. But it might be a good idea to get them if you want your aligement perfect.
  16. Mar 16, 2011 at 2:19 PM
    dza1284
    CA
    This is getting expensive quick.
    If I just put a spacer on the front, an add a leaf in the back and the differential drop, will I be on my way?
    I don't do any hardcore offroading. If I do, i am not hauling a$$ and bottoming out the suspension. I don't want to get this if its going to really f up my ride, and I dont want to spend a lot on a really nice suspension if I don't need it.
  17. Mar 16, 2011 at 2:45 PM
    Steezyskis
    Steezyskis I ski I work I'm rad
    Spencer
    Lake Tahoe (west shore)
    Black 05 DC 4x4 sport SB
    Tuff country front bumper, Walker Evans 2.5 coilovers, Allpro 3" rear leafs with 5100s and an Allpro U-bolt flip kit, K&N CAI, 16x8 Raceline raptor wheels wrapped with 285 Toyo ATs, Sockmonkey bed decals, Softtopper camper shell, half debadged with black painted tacoma emblems, B.A.M.F rock sliders, GT covers, BHLM, PIAA lights and more to come.
    The bitterness of poor quality remains long after the sweetness of a low price is forgotten.
  18. Mar 16, 2011 at 2:47 PM
    JLee
    Jerry
    Bay Area NorCal
    X1,000,000 [​IMG]
  19. Mar 16, 2011 at 2:58 PM
    dza1284
    CA
    Yes I am aware, but is putting a spacer really that bad for limited off roading?
  20. Mar 16, 2011 at 3:10 PM
    dza1284
    CA
    OKK so after reading a bit I am thinking about the Bilstein in the front. Toytec doesnt seem to sell just the front shock. Where is a good place to get this? Say I do that, would the front be taken care of or would I need to get anything else?
    Also what AAL (size/brand/where to buy) would you recommend for the rear? Is that all i need in the rear?
