Small lift question.
Discussion in 'Suspension' started by Fabulous, Apr 8, 2010.
  1. Apr 8, 2010 at 9:20 AM
    Fabulous
    Fabulous [OP] Well-Known Member
    Fabian
    Calgary, AB
    2006 Tacoma double-cab TRD Sport
    Homertaco grill, Light Racing UCA's, 2.8" front lift (5100's at 0.85 setting and Eibach springs) 2" AAL with rear 5100's, Wet Okole seat covers fr/ bk. 17 x 9 Incubus Crusher wheels w/ 4.5" backspacing. 30% tinted front windows.
    I have a 06 D-cab short box TRD Sport, and am curious about lifting my truck about 2" with the 5100's and an AAL. My truck is not eligable for the TSB, so I am thinking about the AAL to allow for a bit more weight in the back...not a lot, just two full size dirt bikes= 500-600 lbs. My truck doesn't bottom out now, but then again I don't really put a lot of weight in it...usually pull the dirt bikes on a trailer. My truck sits pretty level, with the back end maybe 0.5-0.75 inches higher than the front, but the truck has definitly settled over time. I don't think I want a full lift, and the problems associated with it...just like 2-2.5 inches higher than now. If I get an AAL from Toytec, should I get the 1.5, or the 2 inch, and then which setting should I have the 5100's set at? I will be getting the 5100's all the way around by the way. Any help is really appreciated. Thanks.
  2. Apr 8, 2010 at 9:23 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I vote for the 2.5 Billy setting and the 1.5 AAL.
  3. Apr 8, 2010 at 9:28 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
  4. Apr 8, 2010 at 9:35 AM
    Fabulous
    Fabian
    Calgary, AB
    Will it make the ride rough with the 5100's set at the 2.5 on stock springs? With the setting at 2.5, will it make my truck level, because if so, I'd rather have the back sit a tad higher like it is now so it doesn't sag with a load in it...
  5. Apr 8, 2010 at 9:36 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    You should be level.
  6. Apr 8, 2010 at 9:40 AM
    Fabulous
    Fabian
    Calgary, AB
    Hmmm...I was hoping to have th back sit at least half an inch higher than the front...would the 1.75 setting work better to achieve this?
  7. Apr 8, 2010 at 9:43 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Yea. Or buy a 2" aal
  8. Apr 8, 2010 at 9:45 AM
    P-Hill Tacoma
    P-Hill Tacoma Well-Known Member
    Missouri
    2010 DC Short Bed 4WD Off Road Barcelona Red
    Fr Bilsteins@1.75", Rr Bilsteins w/ 1.5" AAL & RideRite Airbags, Truxedo Lo-Pro Tonneau, Step Tubes, 1.25" Spidertrax
    I installed the 1.5 AAL from Toytec with no TSB and new rear 5100 Bilsteins and it was exactly 1.75" higher after. I installed the Bilsteins at 1.75 in front and it was exactly 1.75" higher.
  9. Apr 8, 2010 at 9:48 AM
    Fabulous
    Fabian
    Calgary, AB
    That's what I'm thinking. With the 2" AAL, and the 2.5 setting is it going to be hard to align, and will the ride be a lot rougher than stock? I've read through here, and a lot of threads say that the 5100's at 2.5 really compresses the stock coil, and make the ride rough...
  10. Apr 8, 2010 at 9:48 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Your leafs may have not settled. Rear shocks don't provide lift.
  11. Apr 8, 2010 at 9:50 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
    I have the DC short box TRDsport.
    I bottomed out pre-TSB with just one dirt bike back there - and it was a 2-stroke. Granted, I also had my ramps, tool box and riding gear but I was shocked the first time it slammed off the bumps. I have also bottomed out post-TSB with 2 dirt bikes (both 2-strokes) and riding gear.
    I have read that the 2.5 setting does make the ride a bit more stiff but it should also handle well. I never thought I would get used to the stiff suspension of my former 1st gen but I grew to like it. Those without the factory TRD suspension say it's a major improvement.
    I was going to go Billie 1.75 up front and a TSB AAL that adds 1.5 in the rear. I've decided to go full OME up front (should add 1.5-1.75") and Toytec 1.5" aal in rear for $600 shipped.
  12. Apr 8, 2010 at 9:55 AM
    Fabulous
    Fabian
    Calgary, AB
    $600 is pretty good, but I live in Canada, and I'm sure shipping/ duty would kill me. I want to keep the cost under $1000 Canadian for everything... I'd also like to replace the back shocks at the same time I do the fronts, and I'd like them to match, cuz I'm weird like that.
  13. Apr 8, 2010 at 9:55 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Do 1.75" front and 1.5" rear then.
  14. Apr 8, 2010 at 10:06 AM
    jmed99
    jmed99 Well-Known Member
    SC
    09 DC PreRunner TRD OR
    Do 2.5" on the front shocks and the 2" AAL.
  15. Apr 8, 2010 at 1:23 PM
    Fabulous
    Fabian
    Calgary, AB
    How do the 5100's work in regards to the settings? Like is the 1.75 setting 1.75" of lift, and so on? Will the 5100's set at 1.75 be a smoother ride as it isn't pre loading the stock coil as much? Maybe the 5100's at 1.75, and a 1.5" AAL is the ticket...
  16. Apr 8, 2010 at 1:40 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Each setting is the lift. So yea. .85", 1.75", and 2.5".
  17. Apr 8, 2010 at 3:56 PM
    Tacofanatic05'
    Tacofanatic05' #1 Member
    Hunter
    Waynesville/Charlotte,NC
    05' Tacoma 4x4 sr5, 3 Inch lift
    16'' American Racing wheels, 285/75/16 Cooper Discoverer St tires, Bilstein 5100 w/eibach coils, K&N Cold Air Intake, Flowmaster Super 44, 1 in 2 out exhaust. Tractor Supply Tool Box, No Mud Flaps, Mossy Oak Seat Covers, Oakley Decals, Hoyt Decal, Window tint 20% on sides 5% on top front windshield, Uniden Cb, and Window Deflectors.
    This is exactly what i would do!
  18. Apr 16, 2010 at 9:29 AM
    Fabulous
    Fabian
    Calgary, AB
    After reading on here a tonne, I wonder if the billy's at 1.75 with the stock coils will be too rough (wife drives the truck as well, and loves the way it rides) I was wondering if some new coils with the billy's at 0.85 or 0 would be better? I've also been looking at the OME 3" lift on the Toytec site, and I'm pondering that as well, but I'm worried about going too high, and having to get new UCA, and having problems with the CV's and the boots etc... All I really want is 2-2.5" of lift with a nice ride, and no headaches.
  19. Apr 16, 2010 at 10:46 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Maybe get the 1.6" lift coils and set the billies to .85?
    1.6+.85 = 2.45"
  20. Apr 16, 2010 at 12:14 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    fab. my target was 2" of lift. i put on 1.5" aal for the rear. in the fronts i used the OME setup. i opted for 884 coils, the 90000 shocks, and NO spacer. i measured a stock truck a few days ago, and i got 2.25" in the front, and a true 1.5" in the back. i bet on your double cab, you will have tad less up front, for that bit of rake.
    FYI, there is some guy selling the same kit i bought NIB for cheap in the classifieds.
