Small lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taconator, Mar 26, 2019.
  1. Mar 26, 2019 at 5:36 PM
    Taconator
    Taconator [OP] Active Member
    Manassas, Va, USA
    07 Base Ac Cab 4x4 V6 6 spd
    I'm looking to do a small simple lift on mt TRD/OR. I know most people don't like the idea of a small spacer lift but I have weighed the trade offs and this is what I want to do. I'm looking to do a spacer lift on the front that I can do with out replacing the top studs, I thinks it's 1/4 inch spacer and a 1/2 lift, this would suit me fine considering the cost and complexity of the install. the big question is. Can I just undo the top three nuts and lower the shock assembly just enough and slide in the space and put it back together. Or do I have to completely remove the shock assy to put the spacer in?
    Thanks
  2. Mar 26, 2019 at 5:51 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Is it worth that much effort for little to no gain?
    There may be better options for what you want to accomplish
  3. Mar 26, 2019 at 6:40 PM
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    I don’t know. Try it and see.
  4. Mar 26, 2019 at 11:29 PM
    Roddy13
    Roddy13 Well-Known Member
    1/4 inch spacer does not require new studs... that will give you a 1/2" lift.
    The 1/2 inch spacer requires new studs to be pressed in but will give you a 1" lift. Which is actually level on these trucks
    Look up the bilstein 5100 install videos without a spring compressor ... you can find it here in a few threads or on YouTube ..it will show you how to access the assembly as a whole.. and you can draw to your own conclusion about how easily you can put the 1/4 inch spacer on.
  5. Mar 27, 2019 at 12:03 AM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    That seems like it’s not worth it to go through all that hassle. Do 1”. I did 1” all the way around and I love it.
