Small little rattle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06bluetacoma, Jul 14, 2022.
  1. Jul 14, 2022 at 4:54 AM
    06bluetacoma
    06bluetacoma [OP] New Member
    I was just curious cause I’m very paranoid person, but when I’m accelerating at low rpm’s or reversing I tend to hear a small rattle and was just curious if I should worry. It’s been this way since I bought the truck 4 months ago.
  2. Jul 14, 2022 at 5:22 AM
    Inbred
    Inbred Well-Known Member
    Phinnius
    2nd generation euphoria
    I have a buddy who went through the same thing. He paid a tech $500 to a tech to go through and check the torque on every bolt on the truck. Couldn't find the rattle. Took it to two more garages, same thing. Still, no one could find the rattle source. My buddy asked around and found the best journeyman master mechanic in the whole county and he took it in there. The old mechanic said it would be $1000, but guaranteed he could find source of the rattle or money back. After being paid, he walked over sat in the front seat and looked around. He lifted a coffee mug out of the center console and checked underneath. There it was. Two nickels underneath causing the mug to rattle.
    RedWings44, Tacoma Mike and pahaf like this.
  3. Jul 14, 2022 at 5:48 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Cat cover. Go under and check the heat shield
    TACOMA2NDGEN likes this.
  4. Jul 15, 2022 at 3:47 AM
    SWPA Tacoma
    SWPA Tacoma Well-Known Member
    Stevo
    2006 White Tacoma DCLB
    Heat shield would be my guess too. I have older vehicles, they all seem to develop rattling heat shields at some point. Subarus are the worst.
  5. Jul 15, 2022 at 4:22 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    X3 on a heat shield
  6. Jul 15, 2022 at 7:06 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I had a small rattle that was driving me nuts. I would only here it a low speeds. Turned out I installed a new tonneau cover and the clips up near the rear window was rattling up against the moulding. But i also would check the heat shield. Sometimes you can get a rattle from the wheel arch liners. The clips come loose
  7. Jul 15, 2022 at 10:03 AM
    bmcclain90
    bmcclain90 Well-Known Member
    I have the rattle as well and am pretty sure that it’s the cat heat shield, what is the easiest way go fix this? Can I just remove and run without it?
  8. Jul 15, 2022 at 6:17 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Take a look at the exhaust system and check for loose heat shields. Also, a loose skid plate can cause a rattle.
    IMO, I wouldn’t remove a catalytic converter heat shield. They get pretty hot. If it’s loose, tighten/replace the hardware.
    https://www.ferberstireandauto.com/blog/why-does-my-catalytic-converter-overheat
  9. Jul 15, 2022 at 6:42 PM
    Swb_05
    Swb_05 Member
    Casey
    2005 Speedway Blue TRD OR
    X2, had the same problem on mine. Picked up a hose clamp of the right size and took care of the problem. Guess we will see how the "fix" holds up.
    Hardscrabble[QUOTED] likes this.
  10. Jul 15, 2022 at 11:11 PM
    Gtlegacy
    Gtlegacy Active Member
    How many miles on the truck? Idler and tensioner pulleys can create a rattle if they go bad.
  11. Aug 25, 2022 at 12:46 PM
    foothill96tacoma
    foothill96tacoma Well-Known Member
    The cat shield was loose on my 2014. The bolt holding the clamp tight had rusted away. I bought a new clamp (900080-46121), a bolt, and a washer. My rattle is now gone.
    A hose clamp would work too I imagine.
