"Small Lower Grill Removal"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jrh88er, Jul 16, 2010.
  1. Jul 16, 2010 at 6:28 PM
    Jrh88er
    Jrh88er [OP] New Member
    Doug
    Jacksonville, FL
    2009, Doublecab TRD, 2wd
    How do I remove the "small grille" in the bumper that is beneath the larger grille? I thought it was a "pop-out" but it does not seem to me...thanks...doug
  2. Jul 16, 2010 at 6:43 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    its made to the bumper
  3. Jul 16, 2010 at 8:26 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    dremel??!
  4. Jul 16, 2010 at 8:30 PM
    tbturner47
    tbturner47 Well-Known Member
    Hickory, NC
    '16 Barcelona Red TRD Off Road
  5. Jul 17, 2010 at 3:14 AM
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    Sawsall worked for me. Just go slow and be very precise when cutting.
    Take your time....and you will be fine. Pic below is upper and lower Grillcraft.
  6. Jul 17, 2010 at 9:48 AM
    ChaseUA
    ChaseUA Well-Known Member
    Chase
    Bama
    Present: 2016 White TRD Sport DC Past: 2010 MGM TRD Sport AC 4x4
    FYI: I installed a grillcraft upper and lower and thought it looked better with the lower grill staying in place and installing the grillcraft insert over it.
    I did however cut the top grill out before installing the upper grillcraft.
  7. Jul 17, 2010 at 9:52 AM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    I cut mine out with a thin hand saw, sanded, bondo'd where necessary, and painted. Came out great. Now if I can find some way to put in anchors for my mesh I will be done. I'm using the ABS screw boss idea, like I did on my upper, but I haven't found any product that glues well to the bumper which isn't abs, more like some sort of polyurethane.
  8. Jul 17, 2010 at 10:11 AM
    ChaseUA
    Chase
    Bama
    Heres a picture of my install and I did not remove the lower grill.
  9. Jul 17, 2010 at 10:11 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    like most said thin hand saw or dremel will do the job...
    here's mines satoshi style (RGM & RBM)...:D ENJOY...
  10. Jul 17, 2010 at 1:52 PM
    rdcar
    rdcar Well-Known Member
    07 tacoma
    What did you use to get the toyota emblem on and how did you do it. About to get mine done and will send pics soon
  11. Jul 17, 2010 at 2:43 PM
    T0LLPHR33
    BSP TRD Off-Road
    either 3m double sided tape will work...if you want something more secure you have to use bolts and lock nut washers...
  12. Jul 17, 2010 at 3:24 PM
    ChaseUA
    Chase
    Bama
    Someone else beat me to the response, but it was the "Super Heavy Duty" double sided tape by 3m. You can find it at Lowes/Hope Depot for about $4 a roll. It is VERY secure.
  13. Jul 18, 2010 at 9:01 AM
    rdcar
    07 tacoma
    Thanks
    Trying not to use bolt so screws doesn't show. I was just afraid it will come off and fly if I use a double sided tape. How long have you guys had it on without anyproblem?
  14. Jul 18, 2010 at 9:06 AM
    ChaseUA
    Chase
    Bama
    I've had mine on for 3 months, it is just as "snug" on it as the day I put it on though. You can pull on the emblem and you would think it was superglued/bolted onto the grill.
