Small oil leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by Oldman71, May 1, 2021.
  1. May 1, 2021 at 8:11 PM
    Oldman71
    Oldman71 [OP] New Member
    2004 Black Taco TRD
    Any suggestions on where to look..small oil leak rear of engine..I can see oil on exhaust pipe below exhaust manifold on driver side. Was wondering if it was a common problem with 3.4 & where it could be leaking from. I don’t believe it’s coming from the valve cover.
    ‘04 Taco DC with 124k
  2. May 1, 2021 at 8:35 PM
    1997tacomav6
    Denver
    Photo?
    It’s usually the valve cover gaskets,
    Or possibly the front diff vent valve
    Oldman71[OP] likes this.
  3. May 1, 2021 at 8:40 PM
    SLAPS 65
    SLAPS 65 Dirty deeds, done dirt cheap..
    Leif
    Nor Cal east Bay Area Ca.
    2000 Tacoma 4wd ex cab 3.4 auto.. manual hub, J shift
    I’d bet its the rear cam plug.
    Oldman71[OP] and 1997tacomav6 like this.
  4. May 1, 2021 at 8:42 PM
    Oldman71
    2004 Black Taco TRD
    Thanks for the reply.
  5. May 1, 2021 at 8:47 PM
    1997tacomav6
    Denver
    Cam plugs or half moons if it’s not the valve covers
    These are done with the valve covers gaskets
  6. May 1, 2021 at 9:00 PM
    Oldman71
    2004 Black Taco TRD
    Thanks for the replies..you’ve given me a good starting point. Is it common for the cam plugs to go bad at 124k?
    1997tacomav6 likes this.
  7. May 1, 2021 at 9:01 PM
    1997tacomav6
    Denver
    Yes and no, but remember those gaskets are 20 years old so yes,
    Get a mirror and look behind there, it will be obvious or your hands to see if you can feel oil there
    Oldman71[QUOTED][OP] likes this.
  8. May 1, 2021 at 9:58 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    This is kind of common. I have a leak as well and mine is at the cam plugs. I'm redoing it all and you need quite a few things to do it correctly.
    1 X Toyota FIPG Sealant 00295-00103
    4 X Halfmoons 11183-62010 (I think it is 4 but it might be 2. I haven't looked closely to see.)
    2 X Cam Plugs 11188-62010
    2 X Intake Plenum Gaskets 17176-62040
    1 X Throttle body gasket 22271-62050
    2 X Valve cover gasket 11213-62020
    6 X Spark Plug tube seals 11193-70010
    16 X Valve cover washer seals 90210-05007
    Oh yeah, and while you are in there you might as well do your wires, spark plugs, and PCV valve and rubber grommet.
    skeezix, unstpible and Oldman71[OP] like this.
  9. May 2, 2021 at 5:48 AM
    1997tacomav6
    Denver
    If you have a 3.4 motor this is a very common repair that you WILL have to address sooner or later.
    I’ve had to do mine 3 times in 660,000 miles in 24 years
    Read through this link and you will know what your up against.
    It’s not a hard job, just time consuming,
    1st timer might take 6 hours going slow. Maybe 2 or 3 hours if you know what your doing and have all the parts and no hiccups.
    Cleaning everything is time consuming
    But there are a few things to be aware of if you do the job,
    1) if the plastic wire harness starts to break apart, probably will use tesa tape to
    wrap it and keep it together
    2) torque numbers, valve covers are in inch pounds NOT FOOT
    3) getting half moons out without damage, pulling straight out, if you wiggle back and forth will break the lip on them
    4) taking photos so you remember how all the hoses line up
    5)getting ALL the old gasket material off the heads and valve covers,
    6) use a dremel, wire wheel a the hand wand to get down in the joints.
    https://www.tacomaworld.com/threads/valve-cover-gasket-replacement-3-4-v6-tips.301900/
