Small oil pan leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by CoreyF, Jan 20, 2014.
  1. Jan 20, 2014 at 3:45 AM
    CoreyF
    CoreyF [OP] Corey
    Suffolk, VA
    2013 Tacoma 4WD SR5 Access Cab V6 Automatic
    99 Tacoma 4WD 2.7L 4 cylinder 3RZ-FE 5-speed manual.
    I have a very small oil pan leak just on one side of the flange. I only add about 1/2 quart of oil once a month or so. Would it be ok to just try to tighten the pan bolts just a tiny bit to stop the leak? I'm leery about causing it to leak worse though. This model does not have a gasket just sealant.
  2. Jan 20, 2014 at 9:21 AM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    i'd say that isn't a bad idea, or next oil change before you refill put some rtv around it and let it dry.
    b/c it's 4wd taking the pan all the way out is prob. too difficult to be worth it, but you could prob. drop it enough get enough space to put some more sealant
