Small Problem Solutions
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoman101, Jan 10, 2010.
  1. Jan 10, 2010 at 12:28 PM
    tacoman101
    tacoman101 [OP] Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    I have a bulb out behind my heater control knob and was wondering what type of bulb it takes. It seems to be orange. Also when I drive with the cruise on whenever I hit a bump, it turns off the criuse. What is this from? Thanks
  2. Jan 10, 2010 at 4:13 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    no solution but i have a bulb out behind one of my knobs too. waiting for a response also
  3. Jan 10, 2010 at 4:21 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    Check out Sylvania. I think it's a 194 bulb.
    My truck also sucks to use cruise control. It does the exact same thing as yours. I believe it's because of the clutch. Because if you barely tap the damn thing the cruise disables. Probably something you can do with the sensor or switch to fix it, but I never use cruise since I'm always shifting from 5th to 4th when I'm on the freeway anyways...damn lack of power...
  4. Jan 10, 2010 at 4:35 PM
    clarkie152
    MA
    2016 4Runner Trail
    i checked it says 194. but idk. i replaced my license plate bulbs with a 194....are they THAT big in there?
  5. Jan 10, 2010 at 7:34 PM
    da0023
    da0023 The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    i had to replace some on my 99 behind the heater controls. mine were a really small bulb, a whole lot smaller than 194, they are about the size of a sunflower seed, autozone should have them. fyi, mine had a green rubber cover over them that you have to take off and put on the new one.
  6. Jan 10, 2010 at 7:37 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    No, I just went to the dealer to get mine. They come ini a pack of 3. there little bulbs with a red connector on the back. I'll try to get the part #
  7. Jan 10, 2010 at 7:43 PM
    Faus
    Faus Member
    Spokane, WA
    1998 Tacoma SR5 4x4
    Grey Wire Mod, Flowmaster 40 series w/ flowmaster high flow catalytic converter. 3" add-a-leafs, 2.5" coil spacers
    This was one of the first things i had to replace on my truck. The original bulb is a sylvania 74, which is significantly smaller than a 194. I remember replacing them with sylvania 2721 bulbs because they were slightly higher wattage. I've had them in for about 2 months now with no problems. Edit: Just noticed the post above and i should add, this was on a '98 truck the bulbs may have changed (ie: '01+ trucks might use a different bulb).
  8. Jan 10, 2010 at 7:44 PM
    ETaco23
    Evan
    PNW
    part# 90010-05120
    I got 2 left....
  9. Jan 10, 2010 at 8:01 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I believe you just answered a question I've been trying to figure our for a long time. I was trying to adjust the clutch interlock switch and I noticed another button the pedal hits when the clutch is completely engaged (your foot is completely off the clutch). I couldn't figure out what it was for and now I believe it's for the cruise.
    As for your problem, you could short that out, but that may be kinda dangerous :eek:
  10. Jan 11, 2010 at 8:31 AM
    mx04taco
    mx04taco Well-Known Member
    Cory
    Marietta,GA
    04, SR5, TRD, 4wd
    Flowmaster exhaust, Pioneer DVD HU, Pioneer speakers all around, , Viper security w/ remote start, Tinted Windows, Silverstar Headlights, Toytec 3" Coil Springs, All Pro Offroad Diff Drop 3/4", Bilstein 5100s, 2" Toytec AAL's, Toytec poly rear leaf bushings, Deckplate Mod 4", 265/75r16 firestone destination a/t's
    go to the parts store and ask them to look it up, or take it out and bring it to a parts store and match it up. shouldnt be hard at all to find the right one. 194 is definitely too big
  11. Feb 14, 2010 at 4:28 PM
    SilverTacoma01
    SilverTacoma01 New Member
    Chester, VA
    Toyota Tacoma SR5 Xtra Cab
    Cap on the back
    I'm looking for info on how to changet the climate control bulb (90010-05120) on the instrument panel of my "01 Tacoma. I've taken the knob and first panel off before to look inside and want to make sure I can change it before I order the bulb from the dealer. Any ideas?
  12. Feb 14, 2010 at 4:50 PM
    ETaco23
    Evan
    PNW
    I did what you did, just take off the first panel so you can see the bulb and get to it. It was a tight squeez, but I got it in there.
