Small Split in CV Boot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maticuno, Jan 3, 2012.
  1. Jan 3, 2012 at 4:11 PM
    Maticuno
    Maticuno [OP] Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's
    As the title says, there is a small gash in the CV boot. The boot is still in great shape, and the split doesn't go all the way through as it's not leaking grease. Should I worry about trying to seal the split before it spreads into a full blown tear? Silicone? Gasket sealant? Some other flexible glue? Thanks.
  2. Jan 3, 2012 at 4:42 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    I'd throw some ultra black rtv on it, personally.
  3. Jan 3, 2012 at 4:48 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Yes.
    Re-booting CVs is relatively easy, but time consuming and messy. Better to not have them split in the first place if you can avoid it.
    This. Fill it with something flexible but tough, a la RTV.
  4. Jan 3, 2012 at 5:28 PM
    Maticuno
    03 F250 CCSB
    Thanks for the advice. I just slapped some flexible sealant on it. I'm going to be getting a 2" lift soon and I'm almost positive I'll have the needle bearing noise. If I can make these boots last long enough, I'll replace both axles at the same time ECGS comes out with their bearing replacement bushing. (Odd logic, but it works for me.)
  5. Jan 3, 2012 at 6:31 PM
    jandrews
    Can't hurt to try sliding the boot down the axle a bit and re-clamping. I did it on mine, and it's holding up so far.
